I am wondering if it is possible to add an openstreetmap tile layer to a MapView using the Android API? Or is it only esri map servers that work?
You can open the layer in ArcMap using the ArcGIS Online, save it to an MXD, publish the service, and hit the service with ArcGISTiledMapServiceLayer class. I have also cached the data using the server cache tools in toolbox, copied the data to the device, and called ArcGISLocalTiledLayer, so I can use the maps offline.
http://help.arcgis.com/en/arcgismobile/10.0/apis/android/api/index.html?com/esri/android/map/ags/Arc...
