Find and Replace Null values in ModelBuilder
11435
8
05-21-2012 11:26 AM
CraigPrisland
Hi all,
I'm trying to create a model that will take selected feature classes, search their attributes, and remove any <Null> values in these tables.  Some of these fields will be an integar field type so I would need to replace these <Null's> with 0.  Do you have any ideas to go about this?  Thanks in advance!
NobbirAhmed
Esri Alum
You can do it ModelBuilder but in a cumbersome way. You will need to embed two extra models and a script tool in a main model. Instead, use this script - simple and straightforward.
import arcpy import os  # replace data path with your OWN data. in_data = r"C:\data\f.gdb\parcels"  field_list = [] numeric_fields = ["Double", "Integer", "SmallInteger"]  fields = arcpy.ListFields(in_data) for field in fields:     if (field.type in numeric_fields):         field_list.append(field.name)  # convert the list of fields to a semicolor delimited string fields = ";".join(field_list)    rows = arcpy.UpdateCursor(in_data, '', '', fields) count = len(field_list)  for row in rows:     for k in range(count):         if row.isNull(field_list):             row.setValue(field_list, 0)         rows.updateRow(row)
Let me know if you have any trouble.
If you want you can modify the script a little bit to use it in a script tool.
EricRice
Esri Alum
One way I quickly thought of is to just convert the feature class to a shapefile.  Shapefile's do not support Null entries and automatically convert Null to zero.
Regards,
Eric
NobbirAhmed
Esri Alum
In ModelBuilder, try using Iterate Field Values iterator - you'll get it from the Insert menu > Iterators.
Make your data input to the Iterate Field Values as follows:
[ATTACH=CONFIG]14519[/ATTACH]
The iterator iterates through each value of a chosen field of the selected features. If there is no selection then it iterates all features. To get 0 for null values, be sure to set Null Value to 0 (last parameter in this dialog).
[ATTACH=CONFIG]14520[/ATTACH]
In the above dialog, for the BEAT field of crime data, all <null>s will be replaced by 0 (in this case). You can replace null with any other value (such as -9999). Hope that helps. Thanks.
CraigPrisland
Thanks for the responses.  Is there anyway to search all of the fields in the selected map layers and not just one field?
NobbirAhmed
Esri Alum
CraigPrisland
That worked great.  Thanks!
AmandaKuepfer
This thread seems to be the answer to my issue but I can't quite get it to work.
Basically, I am looking for a way to replace <Null> by -9999 in multiple fields at once, using ArcGIS 10.1. The Find and Replace function in the Attribute table doesnt seem to work for <Null> cells. I've never used the ModelBuilder option and wondered if either of you could explain the steps / code in more detail? In particular, could you highlight the sections I need to adapt so it works for my own data? (I tend to get confused with what's script and what's user-specific :/)
My file name 'data' and address is:
"C:\Users\Amanda K\Desktop\NN\data.gdb\data"
Field names include: sst, chl and sal.
Any help would be much appreciated.
Regards,
Amanda
CraigPrisland
import arcpy
import os
field_list = []
for row in rows:
        rows.updateRow(row)
I am also trying to incorporate "float" field types as well into this script.  I am adding "float" into this line: numeric_fields = ["Double", "Integer", "SmallInteger", "Float"].  However, the float field does not update.  Any ideas?  Thank you in advance.
NobbirAhmed
Esri Alum
Consult this topic:
Field (arcpy)
The field types in arcpy.Field object are mapped as follows - float type is mapped to Single. So, use 'Single' instead of 'Float'
Blob �??Blob
Date �??Date
Double �??Double
Geometry �??Geometry
Guid �??Guid
Integer �??Integer (Long Integer)
OID �??Object ID
Raster �??Raster
Single �??Single (Float)
SmallInteger �??Small Integer (Short Integer)
String �??String (Text)
