I have a simple script that exports a map to a JPEG. Here is the meat of it:
print "generating ouput of " + mxdPath
mxd = arcpy.mapping.MapDocument(mxdPath)
arcpy.mapping.ExportToJPEG(mxd, outputPath, 'PAGE_LAYOUT',1024,1024)
Pretty easy. Problem is there is a ton of SDE Connections, that in turn throw a "Spatial Connection Dialog" that stalls the script. I found a blog or a forum post that said if I use the "CreateArcSDEConnectionFile_management" GP to create the .sde files before I tried exporting the jpeg, I wouldn't get the Spatial Connection Dialog. Seemed to work ok but the problem is every time I run this script i need to create some 10 .sde connection files for the different SDE servers.
# create temporary connection files in memory
print "create ArcSDE Connection files"
try:
print 'created'
arcpy.AddMessage('create connections')
arcpy.CreateArcSDEConnectionFile_management( sdeConnectionFolder, "Connection1", "Server1", "5161", "", "DATABASE_AUTH", "[USERNAME]", "[password]", "SAVE_USERNAME", "SDE.DEFAULT", "SAVE_VERSION")
arcpy.CreateArcSDEConnectionFile_management( sdeConnectionFolder, "Connection2", "Server2", "5161", "", "DATABASE_AUTH", "[USERNAME]", "[password]", "SAVE_USERNAME", "SDE.DEFAULT", "SAVE_VERSION")
arcpy.CreateArcSDEConnectionFile_management( sdeConnectionFolder, "Connection3", "Server3", "5161", "", "DATABASE_AUTH", "[USERNAME]", "[password]", "SAVE_USERNAME", "SDE.DEFAULT", "SAVE_VERSION")
arcpy.CreateArcSDEConnectionFile_management( sdeConnectionFolder, "Connection4", "Server4", "5161", "", "DATABASE_AUTH", "[USERNAME]", "[password]", "SAVE_USERNAME", "SDE.DEFAULT", "SAVE_VERSION")
arcpy.CreateArcSDEConnectionFile_management( sdeConnectionFolder, "Connection5", "Server5", "5161", "", "DATABASE_AUTH", "[USERNAME]", "[password]", "SAVE_USERNAME", "SDE.DEFAULT", "SAVE_VERSION")
arcpy.CreateArcSDEConnectionFile_management( sdeConnectionFolder, "Connection6", "Server6", "5161", "", "DATABASE_AUTH", "[USERNAME]", "[password]", "SAVE_USERNAME", "SDE.DEFAULT", "SAVE_VERSION")
arcpy.CreateArcSDEConnectionFile_management( sdeConnectionFolder, "Connection7", "Server7", "5161", "", "DATABASE_AUTH", "[USERNAME]", "[password]", "SAVE_USERNAME", "SDE.DEFAULT", "SAVE_VERSION")
arcpy.CreateArcSDEConnectionFile_management( sdeConnectionFolder, "Connection8", "Server8", "5161", "", "DATABASE_AUTH", "[USERNAME]", "[password]", "SAVE_USERNAME", "SDE.DEFAULT", "SAVE_VERSION")
arcpy.CreateArcSDEConnectionFile_management( sdeConnectionFolder, "Connection9", "Server9", "5161", "", "DATABASE_AUTH", "[USERNAME]", "[password]", "SAVE_USERNAME", "SDE.DEFAULT", "SAVE_VERSION")
except Exception as e:
print e.message
# If using this code within a script tool, AddError can be used to return messages
# back to a script tool. If not, AddError will have no effect.
arcpy.AddError(e.message)
This works OK, but is slow when I run through 100 maps as I have to run them one at a time. Is there a better way to do this? Is there a way for me to create these .sde connection files, and in the script somehow reference them?Cheers
