Pop Up Window Results to Data Grid
1087
05-07-2012 12:52 PM
JoanBiediger
Hi All,
I have been searching the samples and have not really found what I am looking for.  I have a popup info window and I would like to be able to have the user click a link in the window and have the results returned to a data grid.
Thanks for your help
TomJacoby
This should work for you.  Its less about the map api and more about getting it to work in the javascript. I use jquery.
Here is the code to make things work:
// <Init> map.graphics.enableMouseEvents(); dojo.connect(map.graphics, "onClick", function(evt) {     map.infoWindow.setContent("<a href='#' onclick='getDataResults(evt.graphic.attributes.Id)'>Get Data Results</a>"); // Assumes id is on the graphic somewhere }); // </Init> function getDataResults(id) {    $.get('/GetSomeResults/' + id,  function (content) {   document.getElementById('resultsGrid').innerHTML = content;  } ); }
and some HTML:
[HTML]<div id="resultsGrid"></div>[/HTML]
TomJacoby
and some HTML:
JoanBiediger
Hi Tom,
Thanks for your help!!
Joan
