Hey folks, I don't mean to beat a dead horse being that i have seen this discussed before, but here is my issue. I am having to merge two sets of property records, the records overlap for about 10 months worth, so i need to weed through them find the duplicate records, verify they are duplicates, and correct accordingly. I have seen code on here that will mark in a designate field all occurrences of a duplicate record with a designated string, however i have not been able to get that python script to work (4021 ArcGIS 10 Pre Release finding duplicates). So in the mean time i am left using Knowledge base solution 31854 which works great if my dupes came only in sets of 2. So any other ideas, or am i missing something here. And just a FYI, i am very green when it comes to Python and scripting in ArcGIS outside of Find Attribute Queries. Thanks
This sort of works for what i need it to do, i'll just have to add an additional step in the process to finalize verification of the records prior to removal.
The licensing restriction is loosened a bit - if you use one attribute field at a time (except for Shape field) then Find Identical tool works on all license levels.
