Finding Duplicates
2409
05-03-2012 10:08 AM
JasonBoothe
Hey folks, I don't mean to beat a dead horse being that i have seen this discussed before, but here is my issue. I am having to merge two sets of property records, the records overlap for about 10 months worth, so i need to weed through them find the duplicate records, verify they are duplicates, and correct accordingly. I have seen code on here that will mark in a designate field all occurrences of a duplicate record with a designated string, however i have not been able to get that python script to work (4021 ArcGIS 10 Pre Release finding duplicates). So in the mean time i am left using Knowledge base solution 31854 which works great if my dupes came only in sets of 2. So any other ideas, or am i missing something here. And just a FYI, i am very green when it comes to Python and scripting in ArcGIS outside of Find Attribute Queries. Thanks
JoeFlannery
Honored Contributor
Have you discovered Find Identical and Delete Identical in the Data Management toolbox?
JasonBoothe
I have, unfortunately my use of it is restricted due to a licensing issue beyond my control.
StephenKruzik
taken from: http://forums.arcgis.com/threads/4021-ArcGIS-10-Pre-Release-finding-duplicates
As long as you have the tables joined together so that everything is one dataset...
Calculate field, and choose the python parser and in the pre-logic:
[HTML]uniqueList = []
def isDuplicate(inValue):
  if inValue in uniqueList:
    return 1
  else:
    uniqueList.append(inValue)
    return 0[/HTML]
then in the calculate field:
[HTML]isDuplicate(!FIELD_NAME!)[/HTML]
JasonBoothe
Thanks Stephen,
This sort of works for what i need it to do, i'll just have to add an additional step in the process to finalize verification of the records prior to removal.
NobbirAhmed
Esri Alum
The licensing restriction is loosened a bit - if you use one attribute field at a time (except for Shape field) then Find Identical tool works on all license levels.
