Make feature layer > Select by attributes loop
3681
04-30-2012 06:06 AM
LouisEarly
This is my first adventure into Python scripting so excuse my ignorance. I am trying to loop through FC's in a GDB and select by an attribute then copy those feature classes into the GDB. Below is my script so far. Where my question lies is, in the 'SelectLayerByAttribute' process how do I specify the feature layer that was created in the previous step as the FC to do the selecting from? See where my question marks are below, that is where im unsure
import arcpy
from arcpy import env
env.workspace = r"\\Wmsmonfs01\gisprod\SDE Data Files\PERMITTING_ABA.gdb"
# Local Variables
GDB = r"\\Wmsmonfs01\gisprod\SDE Data Files\PERMITTING_ABA.gdb"
# Get a list of all feature classes
fcList = arcpy.ListFeatureClasses()
# Loop through each feature class in the GDB
for fc in fcList:
# Put in error trapping in case an error occurs when running tool
try:
# Make a layer from the feature classes
arcpy.MakeFeatureLayer_management(fc, fc + '_LYR')
# Select features by attribute
arcpy.SelectLayerByAttribute_management("?????????", "NEW_SELECTION", "\"Source\" = 'GAI'")
# Copy selected features to GDB
arcpy.CopyFeatures_management("???????", GDB)
LouisEarly
Also I think copy features is the wrong process to use.  What I want is to export the selected features to a new FC and put it into the same GDB
deleted-user-IR249IovB3CN
I'm working on a similar problem and could use some guidance. I am trying to create new feature classes based on an attribute selection loop in python from an existing feature class. I can't figure out how to loop through the attribute values to select in a for loop? Perhaps create a list of unique values and then set up an if then statement?
any guidance is much appreciated.
SolomonPulapkura
import arcpy
# Local Variables
for fc in fcList:
try:
arcpy.SelectLayerByAttribute_management("  ?????????", "NEW_SELECTION", "\"Source\" = 'GAI'")
arcpy.CopyFeatures_management("  ???????", GDB)
You would have to do something like this
fl = arcpy.MakeFeatureLayer_management(fc, fc + '_LYR')
fl_sel = arcpy.SelectLayerByAttribute_management("fl", "NEW_SELECTION", "\"Source\" = 'GAI'")
arcpy.CopyFeatures_management("fl_sel", GDB)
Yes Copy features may not work. Maybe try Feature Class To Feature Class
