How to execute an MS SQL stored procedure and then use the results in arcpy???
2359
07-06-2012 09:29 AM
ShawnaErnst
Any help would be most appreciated...
I need to execute an MS SQL stored procedure which creates a temporary table with xy records, and then interact with that temporary table via arcpy to create a point feature class.  I've got the stored procedure built, and I know how to make an XY event layer and then save the records to a feature class.
Is there any way to execute the stored procedure and then use arcpy to interact with the results?
So far, I cannot find a way to make this work.
