findAndReplaceWorkspacePaths Not Working AND using Python to re-join tables
2065
04-29-2012 04:58 AM
ShanaLowe
I am trying to use the Python findAndReplaceWorkspacePaths function, but apparently am doing something wrong.  We recently rebuilt our SDE database and moved the data to a new user (was owned by SDE, which I know is a big no-no, so we moved the data to a different user).  The FC names are the same, server is the same.  Can anyone help me figure out what I am doing wrong?  I was also wondering if there is a Python method for fixing the table joins that are lost now that the data is oned by the new user.
Thanks in advance for any help.
import arcpy
mxd = arcpy.mapping.MapDocument(r"B:\Temp\PYTHON\Test.mxd")
mxd.findAndReplaceWorkspacePaths(r"Database Connections\Connection to MVNPUSH as SDE.sde",
                                 r"Database Connections\Connection to MVN as EDITOR.sde")
mxd.saveACopy(r"B:\Temp\PYTHON\Test2.mxd")
del mxd
JeffBarrette
Have you tried mxd.replaceWorkspaces?  MXD.findAndReplaceWorkspacePaths doesn't work as well for changing owner information.
Jeff
