Python Scrip that Copies Data in a Field to another Field
6366
5
04-30-2012 08:23 AM
IanLeinwand
I'm trying to copy data from one field to another field within a loop. The issue I'm having is how to define the field from which data is being copied as a
variable. The field name from which I want to copy data changes with each iteration of the loop based on the input datasets name.
Here is the code and I highlighted where I'm having trouble... I either get an error or the data does not copy but the script runs... depends on how I s
specify the field name variable.
See... arcpy.CalculateField_managment section of the code
# combine_ecoregion_tree_species.py
# Created on: 2012-04-25 09:17:22.00000
# (generated by ArcGIS/ModelBuilder)
# Description:
# Import arcpy module
import arcpy
from arcpy import env
# Check out any necessary licenses
arcpy.CheckOutExtension("spatial")
# Set Workspace
arcpy.env.workspace = r"\\Sxftcsls001\m\SDL\Data\Forest_Parameters\FHTET\240m\20111019_L48"
rasterList = arcpy.ListRasters("*", "GRID")
listCount = len(rasterList)
print listCount
for r in rasterList:
if(r.startswith ("f")):
print r
# Local variables:
OutWorkspace = "D:\\Risk_Models\\Ecoregion_Tree_Species\\"
eco_id = "D:\\Risk_Models\\Ecoregion_Tree_Species\\eco_id"
Extent = "-2370945 255315 2273055 3189315"
snap = "\\\\Sxftcsls001\\m\\SDL\\Data\\Snap_Grids\\FHTET\\240m\\L48\\snap"
species_pa = OutWorkspace + r
eco_pa = OutWorkspace + "eco_" + r
species_field = str(r)
print r
print " species code is " + species_field
# Process: Con
arcpy.env.snapRaster = snap
arcpy.env.extent = Extent
arcpy.gp.Con_sa(r, 1, species_pa, 0, "\"VALUE\" > 0")
# Process: Combine
arcpy.gp.Combine_sa([species_pa,eco_id], eco_pa)
print "combine complete"
# Process: Add Field
arcpy.AddField_management(eco_pa, "SPECIES", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "")
arcpy.AddField_management(eco_pa, "OCCUR", "SHORT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "")
print "add field"
arcpy.CalculateField_management(eco_pa, "SPECIES", "species_field", "PYTHON")
print "Calculate Species Field"
fields = arcpy.ListFields(eco_pa)
fieldnames = [f.name for f in fields]
fname = fieldnames[3]
print fname
fname_calc = [str(fname)]
print fname_calc
print fieldnames
arcpy.CalculateField_management(eco_pa, "OCCUR", "%s" %fname_calc, "PYTHON")
print "calculated Field"
DarrenWiens2
You need to wrap field names in !'s when they are used in the field calculator expression.
arcpy.CalculateField_management(eco_pa, "OCCUR", "!" + fname_calc + "!", "PYTHON")
Tip: make your calculation in the ArcMap field calculator and look at the results to see the proper syntax.
IanLeinwand
Thanks... I'm trying that now...
I created a model in model builder with the calculate field tool set do do the calculation I wanted and exported that to python... it did not give me the
correct syntax. It had the field wrapped in [ ]
thanks for your response... I'll let you know how it goes.
IanLeinwand
Just tried that and got an error saying it can't concatenate string and list objects.
IanLeinwand
awsome... this worked... arcpy.CalculateField_management(eco_pa, "OCCUR", "!" + fname + "!", "PYTHON")
it didn't like reading it in as a string...
thanks
Ian
DarrenWiens2
Ah, yeah. I'm not sure what it's trying to accomplish with "fname_calc = [str(fname)]". What I am sure about is this: the script produced by exporting from ModelBuilder is a lie.
