dictionary of all ArcPy toolbox commands
4408
9
04-25-2012 01:56 AM
HugoAhlenius
I frequently do my coding in the excellent text-editor Vim. It has a feature to do text-completion from a dictionary, which I would like to use - is there a plain list of all the toolbox commands + Spatial Analyst functions that one could use?
When I type in Vim I am often not sure about the capitalization etc of the commands.
RDHarles
When you say "toolbox commands", are you talking about the exact name of the tool (with proper capitalization)?
HugoAhlenius
Yes, I am primarily thinking of all the arcpy.something tools (not the arguments etc though). Maybe constants and classes would be useful as well.
HugoAhlenius
Hmm, I think I got it - in my iPython console, I just type arcpy. and then pressed <tab> - and I got it all! Another way is to do a dir(arcpy) and dir(arcpy.sa).
RDHarles
The tool ListTools will give them to you too...
for newToolName in arcpy.ListTools():
    print newToolName
HugoAhlenius
Now, how would I get all constants... ?
HugoAhlenius
...as well as functions and classes.
I guess one can always copy/paste them from the help file, if nothing else...
RDHarles
When Arc 10 was first released, I attempted to write a script to convert everything in a 9.x script to a 10.x script.
I never used it and I know there were some issues with it but you can use the ideas/lists/dictionaries from it:
# Updates Tools, Functions, Environments & a few Methods from 9.x to "case-sensitive" 10.x
# Note: Rewrites script(s) to hardcoded "ARC10" directory.
# Thoughts:
#   Can I get a list of all Methods & Properties?
# R.D. Harles
# 11-21-10
import arcpy, os, sys, string
# Output directory for updated scripts
if not os.path.exists("ARC10"):
    os.mkdir("ARC10")
# Create the master dictionary
masterDict={}
# Add tools to the masterDict (with and without the toolbox)
# Note: The "(" is required because some tools start with the same word as others (e.g. gp.select & gp.selectlayerbylocation)
    # Without toolbox (e.g. clip)
    masterDict["gp."+newToolName.split("_")[0].lower()+"("] = "arcpy."+newToolName+"("
    # With toolbox (e.g. clip_management)
    masterDict["gp."+newToolName.lower()+"("] = "arcpy."+newToolName+"("
# Add environments to the masterDict
for env in arcpy.ListEnvironments():
    masterDict["gp."+env.lower()] = "arcpy.env."+env
# These don't get listed for some reason?
masterDict["gp.overwriteoutput"] = "arcpy.env.overwriteOutput"
masterDict["gp.GetParameterAsText"] = "arcpy.env.GetParameterAsText"
# Add functions to the masterDict
functions = ["AddError","AddFieldDelimiters","AddIDMessage","AddMessage","AddReturnMessage","AddToolbox","AddWarning",
"AsShape","CheckExtension","CheckInExtension","CheckOutExtension","CheckProduct","ClearEnvironment",
"Command","CopyParameter","CreateObject","CreateRandomValueGenerator","CreateScratchName","CreateUniqueName",
"Describe","Exists","GetArgumentCount","GetIDMessage","GetInstallIInfo","GetMaxSeverity","GetMessage",
"GetMessageCount","GetMessages","GetParameter","GetParameterAsText","GetParameterCount","GetParameterInfo",
"GetParameterValue","GetReturnCode","GetSeverity","GetSeverityLevel","GetSystemEnvironment","ImportToolbox",
"InsertCursor","IsSynchronous","ListDatasets","ListEnvironments","ListFeatureClasses","ListFields","ListFiles",
"ListIndexes","ListInstallations","ListPrinterNames","ListRasters","ListTables","ListToolboxes","ListTools",
"ListVersions","ListWorkspaces","LoadSettings","NumpyArrayToRaster","ParseFieldName","ParseTableName",
"ProductInfo","RasterToNumPyArray","RefreshActiveView","RefreshCatalog","RefreshTOC","RemoveToolbox",
"ResetEnvironments","ResetProgressor","SaveSettings","SearchCursor","SetParameter","SetParameterAsText",
"SetProduct","SetProgressor","SetProgressorLabel","SetProgressorPosition","SetSeverityLevel","TestSchemaLock",
"UpdateCursor","Usage","ValidateFieldName","ValidateTableName"]
for func in functions:
    masterDict["gp."+func.lower()] = "arcpy."+func
# Add cursor methods to masterDict
methods = ["next","reset","newRow","insertRow","updateRow","deleteRow","getValue","isNull","setNull","setValue","getPart","getObject","removeAll","partCount"]
for meth in methods:
    masterDict[meth.lower()] = meth
# This isn't going to work.  There could be up to 3 replaceable items on one line and only item item per line can be replace the way the script is written.
### Codes and return values
##codesReturnValues = ["ArcView","ArcEditor","ArcInfo","Engine","EngineGeoDB","ArcServer","AlreadyInitalized","Available","Unavailable","NotLicensed","Failed"]
##for crv in codesReturnValues:
##    masterDict[crv.lower()] = crv
# Add misc to masterDict
masterDict["gp = arcgisscripting.create()"] = ""
masterDict["gp = arcgisscripting.create(9.3)"] = ""
# Loop through python scripts
for script in os.listdir(''):
    if script.endswith('.py'):
        print "\nProcessing "+script+"..."
        # Open new file (output to hardcoded "ARC10" directory)
        wfile = open("ARC10/"+script, "w")
        count=0
        # Read existing script (line by line)
        for line in open(script).readlines():
            # Make the line lower case to ensure match with lower case item
            lower = line.lower()
            count=count+1
            # Loop through master dictionary
            for item in masterDict:
                # Get the key (2nd part of the pair)
                key = masterDict[item]
                # Check for a match in the line
                x = lower.find(item)
                # Continue if there is a match
                if x != -1:
                    # Do the search & replace
                    fix = lower.replace(item, key)
                    # Write it (changed line)
                    wfile.write(fix)
                    print " "+script+": (line"+str(count)+") Replacing '"+item+"' with '"+key+"'"
                    break
            if x == -1:
                # Write it (unchanged line)
                wfile.write(line)
                print " "+script+": (line"+str(count)+") Writing original line: "+line
        # Close file
        wfile.close()
        ## Replace arcgisscripting with arcpy
        # Open file in read mode
        file = open("ARC10/"+script, "r")
        # Read entire file
        text = file.read()
        # Closes the read session
        file.close()
        print "\n ...Replacing arcgisscripting with arcpy"
        file.write(text.replace("arcgisscripting", "arcpy"))
        file.close()
print "\nDone.\n"
HugoAhlenius
ok cool, thanks - I have to look at that more closely at some point to see if I understand what your script does. I snooped around in the folder C:\ProgramX86\gis\ArcGIS\Desktop10.0\arcpy\arcpy, and I saw that one can grab a lot of things from those files as well.
BenHolmes
Pyscripter is quite nice to use. It was mentioned in one of the geoprocessing blogs on here
http://code.google.com/p/pyscripter/
