Help: looping funtion to creat a list for the files from different folders
4547
19
08-11-2011 02:20 PM
ZiaAhmed
I am very new in Python.  I am trying to import several featue classess into file geodatabse (name: IA.gdb)  using a script. These files are in located in diffrent folders. For example:
K:\SUURGO_Data\IA\soil_ia001\soil_ia001\spatial\soilmu_a_ia001.shp
K:\SUURGO_Data\IA\soil_ia001\soil_ia003\spatial\soilmu_a_ia003.shp
K:\SUURGO_Data\IA\soil_ia001\soil_ia005\spatial\soilmu_a_ia005.shp
K:\SUURGO_Data\IA\soil_ia001\soil_ia053\spatial\soilmu_a_ia053.shp
K:\SUURGO_Data\IA\soil_ia001\soil_ia193\spatial\soilmu_a_ia193.shp
.... so on
I used model bulider to do this for a  few number of files. But I want to do this with a loop to select (list)  all of these files  and import to a filegeodata base. I do not know how to write a loop function get the list of files located in different folders and subfolders.   Help will be highly appreciated.  Below find a python script - saved from Model Bulder.
Zia
# ImprtFetureGeodatabse.py
# Created on: 2011-08-11 17:44:46.00000
#   (generated by ArcGIS/ModelBuilder)
# Description:
# Import arcpy module
import arcpy
# Local variables:
soilmu_a_ia001_shp = "K:\\SUURGO_Data\\IA\\soil_ia001\\soil_ia001\\spatial\\soilmu_a_ia001.shp"
soilmu_a_ia003_shp = "K:\\SUURGO_Data\\IA\\soil_ia003\\soil_ia003\\spatial\\soilmu_a_ia003.shp"
soilmu_a_ia005_shp = "K:\\SUURGO_Data\\IA\\soil_ia005\\soil_ia005\\spatial\\soilmu_a_ia005.shp"
soilmu_a_ia197_shp = "K:\\SUURGO_Data\\IA\\soil_ia197\\soil_ia197\\spatial\\soilmu_a_ia197.shp"
soilmu_a_ia053_shp = "K:\\SUURGO_Data\\IA\\soil_ia053\\soil_ia053\\spatial\\soilmu_a_ia053.shp"
IA_gdb__2_ = "K:\\COUNTY_MUKEY\\IA.gdb"
# Process: Feature Class to Geodatabase (multiple)
arcpy.FeatureClassToGeodatabase_conversion("K:\\SUURGO_Data\\IA\\soil_ia001\\soil_ia001\\spatial\\soilmu_a_ia001.shp;K:\\SUURGO_Data\\IA\\soil_ia003\\soil_ia003\\spatial\\soilmu_a_ia003.shp;K:\\SUURGO_Data\\IA\\soil_ia005\\soil_ia005\\spatial\\soilmu_a_ia005.shp;K:\\SUURGO_Data\\IA\\soil_ia197\\soil_ia197\\spatial\\soilmu_a_ia197.shp;K:\\SUURGO_Data\\IA\\soil_ia053\\soil_ia053\\spatial\\soilmu_a_ia053.shp", IA_gdb__2_)
MathewCoyle
Honored Contributor
Is there some kind of processing you need to do that requires you to loop through a list? You can simply create a list of shapefiles and bulk load them as you have done.
You could try just making it a list to be more readable
shape_list = ["K:\\SUURGO_Data\\IA\\soil_ia001\\soil_ia001\\spatial\\soilmu_a_ia001.shp",
              "K:\\SUURGO_Data\\IA\\soil_ia003\\soil_ia003\\spatial\\soilmu_a_ia003.shp",
              "K:\\SUURGO_Data\\IA\\soil_ia005\\soil_ia005\\spatial\\soilmu_a_ia005.shp",
              "K:\\SUURGO_Data\\IA\\soil_ia197\\soil_ia197\\spatial\\soilmu_a_ia197.shp",
              "K:\\SUURGO_Data\\IA\\soil_ia053\\soil_ia053\\spatial\\soilmu_a_ia053.shp"]
arcpy.FeatureClassToGeodatabase_conversion(shape_list, IA_gdb__2_)
ZiaAhmed
Hi mzcole:
Thanks for your reply. For example, i just mentioned for exporting  5 shape files in a geodatabse. I have to export 100s of files to a geodatabase. I want to write a loop that can allow me to select  soilmu_iacountyCode.shp from respective subdirectories (soil_iacountyCode\\soil_iacountyCode\\spatial) of K:\\SUURGO_Data\\IA directory.
countyCode = 001, 003, 015......so on. For example, my directory structure like this:
K:\SUURGO_Data\IA\soil_ia003\soil_ia003\spatial\soilmu_a_ia003.shp
...........................\soil_ia005\soil_ia005\spatial\soilmu_a_ia005.shp
........................... \soil_ia022\soil_ia022\spatial\soilmu_a_ia022.shp
............................ \soil_ia160\soil_ia160\spatial\soilmu_a_ia160.shp
Zia
RDHarles
This will find EVERY shapefile in EVERY directory in the path you choose to start from (c:/shapefiles in the example below).
Then you can do whatever you want with the shapefile.
import os
for root, dirs, files in os.walk("c:/shapefiles"):
    for file in files:
        if file.endswith(".shp"):
            path = os.path.abspath(os.path.join(root, file))
            print path
ZiaAhmed
Thanks! If I want to select one particular type of shape file  ending with _a_ia001.shp  from a group of shape files from K:\SUURGO_Data\IA\  directory .. is following code is ok for do this?
for root, dirs, files in os.walk("K/SUURGO_Data/IA/:shapefiles"):
    for file in files:
        if file.endswith("_a_ia001.shp"):
            print path
import os
    for file in files:
            print path
RDHarles
Sure, that will work.
You can combine things as well.
# Examples:
if file.startswith("rd-") and file.endswith(".dbf"):
ZiaAhmed
I am using following code after adding a loop function for creating a list of  of al feature classes. But got some error. I think i miss somthing.. zia
ArcGIs 10 Help
#Code Sample
#ListFeatureClasses example
#Copy shapefiles to a geodatabase.
import arcpy
from arcpy import env
import os
# Set the workspace for the ListFeatureClass function
env.workspace = "c:/base"
# Use the ListFeatureClasses function to return a list of
#  all shapefiles.
fcList = arcpy.ListFeatureClasses()
# Copy shapefiles to a file geodatabase
for fc in fcList:
    arcpy.CopyFeatures_management(fc, "d:/base/output.gdb" + os.sep + fc.rstrip(".shp"))
# This is my script adding a loop funtion
import arcpy
import os
env.workspace= "K:\SUURGO_Data\IA"
# To create list files from directories and subdirectories
for root, dirs, files in os.walk(env.workspace):
     for name in files:
       if file.startswith("soilmu_a_") and file.endswith(".shp"):
              print path
for fc in fcList:
arcpy.CopyFeatures_management(fc, "K:/COUNTY_MUKEY/IA.gdb"" + os.sep + fc.rstrip(".shp"))
RDHarles
I changed quite a bit of the code, this should work now.
import arcpy, os
# Set the workspace
arcpy.env.workspace= "K:/SUURGO_Data/IA"
for root, dirs, files in os.walk(arcpy.env.workspace):
    for name in files:
        if name.startswith("soilmu_a_") and name.endswith(".shp"):
            path = os.path.abspath(os.path.join(root, name))
            # Remove the path from the shapefile name
            base = os.path.basename(path)
            print "Processing "+base
            # CopyFeatures
            arcpy.CopyFeatures_management(base, "IA.gdb/"+base.rstrip(".shp"))
            print arcpy.GetMessages()
ZiaAhmed
When run this script in ArcTool box, it did not work-  it showed "Failed to execute (CopyFeatures). Then I tried in Python2.6Python GUI it showd following error:
Processing soilmu_a_ia001.shp
  File "K:\Script\Python_Script\ImprtFetureGeodatabase_1.py", line 22, in <module>
  File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\management.py", line 1943, in CopyFeatures
    raise e
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000732: Input Features: Dataset soilmu_a_ia001.shp does not exist or is not supported
I am very new in python scripting in ArcGIS, I am not able to figure out what wrong here. Thanks again
import arcpy, os
# Set the workspace
    for name in files:
            # CopyFeatures
RDHarles
My mistake, my environment is set up differently from yours.
Change the word 'base' to 'path' like this:
arcpy.CopyFeatures_management(path, "IA.gdb/"+base.rstrip(".shp"))
