batch reclassify rasters
2464
04-12-2012 09:47 AM
WadeGivens
I'm trying to batch reclassify a set of rasters in ModelBuilder by assigning an interger from 1-8.  So if raster value is 1-1.5 =1.5-2.5=3, ...... 7.5-8=8
I know I can put these values in a table, but it would be nice to embed it in the model for portability.
Thanks!
BrianCohen
Hi
If you want to do it directly with Python, here's an example. Bear in mind that this works on integer rasters, so you will need to modify the remap table function.
# Name: reclassify_example02.py
# Description: Reclassifies the values in a raster.
# Requirements: Spatial Analyst Extension
# Author: ESRI, modified by Brian Cohen
# Import system modules
import arcpy
from arcpy import env
from arcpy.sa import *
import os
# Set environment settings
env.workspace = "N:/South_Coast/Geo_Data/Climate/SDMs/plantsout"
count = 0
# Get list of rasters from workspace
rasterList = arcpy.ListRasters("*", "All")
# sort alphabetically
rasterList.sort()
for inRaster in rasterList:
# set the reclassify field
    reclassField = "Value"
# create the remap value table (here, changing all values to 0 save for 1, which remains the same)
    remap = RemapValue([[0, 0], [1, 1],[2, 0],[3, 0],[4, 0],[5, 0],[6, 0],[7, 0]])
# Check out the ArcGIS Spatial Analyst extension license
# Execute Reclassify
    outReclassify = Reclassify(inRaster, reclassField, remap, "NODATA")
# set the output path
    outpath = "N:/South_Coast/Geo_Data/Climate/SDMs/plantscores/score01/"
# Save the output
    output = os.path.join(outpath, inRaster)
    outReclassify.save(output)
BrianCohen
Hi
import arcpy
import os
count = 0
rasterList.sort()
# Save the output
WadeGivens
That works perfectly.  Now if I could only do this based on unique to each raster, quantile classification....
