Export Feature Attribute to ASCII question
1868
6
04-09-2012 09:25 AM
DC
Does anyone know a way to export every "Value_Field" in a shape file without specifically using the name of every one individually? In other words is there some kind of wildcard value or loop that will just export every single "Value_Field" that is in the shape file?
Based on this:
ExportXYv_stats (Input_Feature_Class, Value_Field, Delimiter, Output_ASCII_File, Add_Field_Names_to_Output)
MathewCoyle
Honored Contributor
I believe you are looking for something like this.
import arcpy
fields = arcpy.ListFields(<your_layer>)
field_text = list()
for f in fields:
    if fields.type != "Geometry":
        field_text.append(f.name)
arcpy.ExportXYv_stats(<your_layer>,field_text,"COMMA","C:/GIS/Exports/test2.asc","ADD_FIELD_NAMES")
DC
Thank you for the reply, but I am really new to python and not sure how that would fit into this:
# Export feature locations and attributes to an ASCII text file
# Import system modules
import arcpy
# Local variables...
workspace = "C:\Users\me\Desktop\InputFolder.ospfds"
input_features = "ShapeFile.shp"
export_ASCII = "ExportFile.txt"
try:
    # Set the current workspace (to avoid having to specify the full path to the feature classes each time)
    arcpy.env.workspace = workspace
    # Process: Export Feature Attribute to ASCII...
    arcpy.ExportXYv_stats(input_features, ["value_field_A","value_field_B","value_field_C"], "COMMA", export_ASCII, "ADD_FIELD_NAMES")
except:
    # If an error occurred when running the tool, print out the error message.
    print arcpy.GetMessages()
DC
Anyone else have any ideas on this?
ScottBlankenbeckler
I would use mathew's solution. Your code should look something like this:
import arcpy
fields = arcpy.ListFields (input_features )
field_text = list()
for f in fields:
try:
    arcpy.ExportXYv_stats(input_features, field_text, "COMMA", export_ASCII, "ADD_FIELD_NAMES")
except:
DC
Ah, I got it to work with a couple changes.  Thank you both for the help!
1.  input_features = "ShapeFile.shp" needed the entire path instead of just the file name in order to work with arcpy.ListFields for some reason
2. "if fields.type != ...." needed to be changed to "if f.type != ...."
DonBarker
Really appreciate you guys taking time to document this.  Am a Python novice, too.  Made a big contribution to my project.
