Difference between AddFieldDelimiters and ValidateFieldName
5321
12-07-2010 12:39 AM
JianLiu2
For the script as below, can I directly use fieldname, rather than newName in SQL? (so delete newName = arcpy.AddFieldDelimiters("C:/Data", fieldName) ...)
If not, why? When to use AddFieldDelimiters? Any difference to ValidateFieldName? Thanks indeed!!
import arcpy
from arcpy import env
fieldName = arcpy.GetParameterAsText(0)
wkspace = arcpy.GetParameterAsText(1)
in_features = arcpy.GetParameterAsText(2)
out_feat_class = arcpy.GetParameterAsText(3)
stateVal = arcpy.GetParameterAstext(4)
# AddFieldDelimieters will return a field name will the proper
# field delimiters for the workspace specified.
# Use delimited field for Select tool SQL expression
sqlExp = newName + " = " + stateVal
env.workspace = wkspace
arcpy.Select_analysis(in_features, out_feat_class, sqlExp)
StephenBarrow
import arcpy
The AddFieldDelimiters will add the correct surrounds for the field depending on the source location for example [field] 'field' field etc as different workspaces need different ones.
Use AddFieldDelimiters when constructing a SQL statement as these save you some work in getting it right.
ValidateFieldName removes invalid characters form a field name (usually user typed) so it will conform and not cause code to crash by replacing invalid characters with an underscore.
hth
Stephen
