Problem Loading the Map
1179
04-05-2012 04:17 AM
demdeberanz
Hi everybody,
I'm trying to show a map inside a sliding tab pane (like this one http://help.arcgis.com/en/webapi/javascript/arcgis/demos/widget/widget_legend.html "in place of the legend") but I'm getting the following error:
"NetworkError: 404 'size' parameter is invalid - http://*************/test/MapServer/export?dpi=96&transparent=true&format=png8&layers=show%3A7%2C4&b..."
Anyone Knows what does it mean?and what is the problem?
Thank you everybody.
demdeberanz
It seems to be an error due to two attributes called width and height in the map_gc div, which is automatically created.
<div id ="map_gc"  width="-16" height="-16" .....>
</div>
these are the only -16 values I find out in the code...
any ideas why are set in this way???
KellyHutchins
Esri Notable Contributor
Can you post a simple code example that shows the problem? In your app is the tab that contains the map visible?
demdeberanz
You hit the problem!!!the map's tab was not visible...I fixed it! Thank you everybody.
