Programmatically change drawing tool
1179
04-01-2012 01:18 PM
GrantCarroll
Hi all
I'm creating an app that will be used exclusively with touch devices, the app will be used to edit point and line features in the field. What I would like to do is have the line feature edit tool default to the free hand tool, i'm not quite sure how to do this though. I am using a template picker so that the users can select which type of feature they are creating, can I set the drawing tool when the template is selected as below ?
 dojo.connect(templatePicker, "onSelectionChange", function () {
                var selected = templatePicker.getSelected();
                if (selected) {
                  $('#featuresDialog').dialog('close');
                  selected.template.drawingTool = 'esri.layers.FeatureTemplate.TOOL_FRREEHAND';
                  updateTitle("Current template: " + $('#webmapTitle').html(selected.template.name));
Do i have the correct syntax ? As when i do this the tool is still defaulted to the normal line drawing tool.
Thanks in advance
Grant
GrantCarroll
I solved this when looking through some of the samples.
Correct code is below
                if (selected) {
                 selected.template.drawingTool = 'esriFeatureEditToolFreehand'
                  updateTitle("Current template: " + selected.template.name);
