MessageBox Not getting focus when run in ArcMap
1498
03-22-2012 08:27 AM
WilliamIde
I have been working on a system that is not connected to this net work so I am going to have type a shorted version
So I create a app window a few buttons and then I do some logic.  Then I ask a question in a askquestion MessageBox.  The problem is this code works when I run it in IDEL.  But when I run as a script from ArcMAP the askquestion MessageBox doesn't get mouse focus.  So the user can't say yes or no.  Why no focus?
import arcpy
from arcpy import env
import Tkinter as tk
import tkMessageBox
root = tk.Tk()
maintitle = tk.Label(root,"Add things to the list")
button1 = tk.Button(root,text="Help",commend=help_call)
buttonq = tk.Button(root,text="Quit",commend=quit_calll)
## do some logic in arcpy
found_one = 0
for field in fieldlist:
    if field[0:3] == "RM_"   # see is any fields start with RM_
         found_one += 1
if found_one == 0:
     lbAnswer = tkMessageBox.askquestion("No RM found"," not RM_ fields found create them?")
     if (lbAnswer == "yes":
          createthe_rm_fields(inputfile)
     else:
          root.destroy()
root.mainloop()
WilliamIde
I found a work around by not using tkMessageBox.  Instead I created a dialog class that does that same job.
GwenLaSelva
Still no fix for this in ArcGIS 10.5, it appears.
