SQL Custom Step - Stored Procedure
4103
02-29-2012 10:35 AM
Jean-GabrielHasbani
I am trying to run a stored procedure, in Oracle, using the SQL custom step. I have WMX 10, Desktop. WMX is installed on the same DB as the stored procedure, I and WMX have execute rights on the procedure.
When running the step, I get the error "An error occurred while trying to execute this step. Underlying DBMS error [Ora-00900: Invalid SQL statement]"
It is not a coding error as I can successfully run the procedure from Oracle, as the WMX user. It is not a permission issue as, for testing, I gave public execution rights on the procedure.
The step is declared as:
/database:jtxsystem /sql:"execute Shema.Package.ProcedureName(param1,param2)"
I have tried, with no luck,the Data DB (same as the jtxsystem DB anyways), and with/without an ending ;
Has anyone succeeded in running a stored procedure from a custom SQl step?
TopeBello
Hi Jean,
Yes, and this is the argument that you can pass into the custom step
/database:jtxsystem /sql:"BEGIN Shema.Package.ProcedureName(param1,param2); END;"
You can also take a look at this forum post here that is related to what you are doing.
I hope this helps!
Tope
TopeBello
Hi Jean,
I hope this helps!
Tope
Jean-GabrielHasbani
Thank you very much! It works perfectly with this syntax!
Jean
