Layer Activation with button/icon
736
02-19-2012 08:11 AM
AzizulAlam1
I am new at JS API. I am trying to learn and apply this API. I want to display a point feature that will activate with click on button or icon or any link. I saw a sample with button click in ArcGIS Google API extension that is called query a point layer. I am giving the code here. I just want the same thing but not with Google.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html debug=true>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
    <title>Query Task (Returns Point)</title>
    <script src="http://maps.google.com/maps?file=api&amp;v=2&amp;key=DioG219lPJG3WTn3zmQqebsjVg" type="text/javascript"></script>
    <script src="http://serverapi.arcgisonline.com/jsapi/gmaps/?v=1.6" type="text/javascript" ></script>
    <script type="text/javascript">
      var gmap = null;
      var qtask = null;
      var query = null;
      var mapExtension = null;
      var gOverlays = null;
      function initialize() {
        // GMap construction
        gmap = new GMap2(document.getElementById('gmap'));
        gmap.addMapType(G_NORMAL_MAP);
        gmap.addMapType(G_SATELLITE_MAP);
        gmap.addControl(new GLargeMapControl());
        gmap.addControl(new GMapTypeControl());
        gmap.setCenter(new GLatLng(33.96964806519751, -117.37674951553345), 17); // RIVERSIDE (Point)
        gmap.enableScrollWheelZoom();
        //Create MapExtension utility class
        mapExtension = new esri.arcgis.gmaps.MapExtension(gmap);
        // Query Task
        qtask = new esri.arcgis.gmaps.QueryTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/0");
        // You can execute a task and listen for the complete event or use the callback to get the results
        GEvent.addListener(qtask, "executecomplete", function() {
          //console.debug("'query task complete' event fired!!!");
        // Query
        query = new esri.arcgis.gmaps.Query();
      function executeQuery() {
        var bounds = gmap.getBounds();
        // clear map overlays and event listeners using MapExtension removeFromMap
        mapExtension.removeFromMap(gOverlays);
        // set query parameters
        query.queryGeometry = bounds;
        query.returnGeometry = true;
        // execute query task
        qtask.execute(query, false, mycallback);
      function mycallback(fset) {
        // add the feature set to google map without any style
        gOverlays = mapExtension.addToMap(fset);
    </script>
  </head>
  <body onload="initialize();" onunload="GUnload();">
  <table width="100%" height="100%">
    <tr>
      <td align="center">
        <table>
          <tr align="left">
            <td>
              <input type="button" value="Execute Query" onclick="executeQuery();" />
              <input type="button" value="Clear Map Overlays" onclick="mapExtension.removeFromMap(gOverlays);" />
            </td>
          </tr>
          <tr align="left" valign="top">
            <td>
              <div id="gmap" style="width: 500px; height:500px;"></div>
            </td>
          </tr>
        </table>
      </td>
    </tr>
  </table>
  </body>
</html>
What I have to do if I do the same thing in ArcGIS Javascript API???
Azizul Alam Toton
Asst. GIS Specialist
Data Expert (Pvt.) Ltd
Bangladesh
EdSaunders
Hi Azizul,
Can you give some more info?  Do you want to display a layer in a web app?  You can do that using the following code:
Add layer to map
       var featureLayer = new esri.layers.FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Hydrography/Watershed173811/MapServer/1",{
          mode: esri.layers.FeatureLayer.MODE_ONDEMAND,
          outFields: ["*"],
          visible: false,
          infoTemplate: infoTemplate
        map.addLayer(featureLayer);
Then, to display the layer
featureLayer.show();
