How to get the ???queried??? value from attribute table and put it in a textbox?
855
02-07-2012 06:55 AM
EmmaOlsson
I am new in VBA, I have a problem about querying an attribute table....:
I have a table of a layer (wish.shp) with the fields: owner_ID, Value, Area.
I made 3 textboxes in a userform, I input the owner_ID, in one textbox, I want to get the corresponding value and area and display in other textboxes.
does anybody know how to do it ?
JohnHauck
You could use ITable::Search or IFeatureClass::Search with a QueryFilter that has a defined where clause with the value you have entered for owner_ID; for example ("owner_ID = " & textBoxValue). Once the cursor is created you could loop through the returned rows and provide the returned value(s) to your UI.
How to perform an attribute query
Querying geodatabase tables
