Converting the geom field into set of google latitudes and longitudes
1103
02-06-2012 01:45 AM
MustafaNoor
I have stored shapefile of type polygon into SQL server table. In my C# application, i want to convert the geometry field into set of google latitudes and longitues.
Is there any Good C# library for this conversion?
Or give me suggestion, how can i do this conversion?
regards
JohnHauck
ArcObjects provide many classes for helping to look at a geometry your feature class would store:
Geometry
Working with Geometry
Working with spatial references
ArcGIS also provides some out of the box tools such as Write Feature to Text File that would handle much of the work for you.
Making sure that your ESRI geometry is using the same spatial reference as required by Google Maps would be also key. You could use the geopocessors Project tool for this prior to writing the coordinate values out to disk.
