Customize popups from web template?
1042
01-25-2012 10:35 AM
ElizabethMiller
Is it possible to change the size of the popups that appear on the web template? They are the wrong size for my data -- they are too large in the vertical dimension and too narrow horizontally, so that they cut off the right side of the attribute information.
KellyHutchins
Esri Notable Contributor
Yes you can use the InfoWindow's resize method to do this. Here's an example that changes the size of the popup for a web map.
 mapDeferred.then(function(response){
        map = response.map;
       map.infoWindow.resize(200,200);
       dojo.connect(dijit.byId('map'), 'resize', map,map.resize);
JuneAcosta
I would like to do the same customization on the simple Map template that I downloaded from ArcGIS online. Is this what you mean by web template- a template from ArcGIS online?
JuneAcosta
I downloaded the Simple Map viewer and need to resize the poup for the same reasons. Which file do I modify to add this snippet of code?
