Modelbuilder - cannot create geodatabase under folder.
1052
01-23-2012 02:00 AM
by Anonymous User
Not applicable
I have created a model where I first let the user select a directory to work in. So it should create two new directories under it, and a geodatabase in the last one.
I get det ERROR 000792: cannot write output to target forlder.
The same model work fine in ArcGis 10.0 sp3.
ShitijMehta
I am sorry you are getting this error. To understand this problem please can you please share your model and/or a screenshot of the tool dialogs used in the model.
Thanks!
by Anonymous User
Not applicable
This is only a simple model I used to see if this went. And as I said. No errors in 10.0, but error in 10.1. It seems that it does not create directories before trying to create the geodatabase.
Have had a colleague with 10.1 to try too. She gets the same error message.
Thanks for your feedback.
BBicking1
Thanks for bringing this to our attention Ann.
A cr is logged and it will be fixed for 10.1 final.
Barbara Bicking
