esri.tasks.query: query.text versus query.where
2887
01-21-2012 05:12 AM
Salomon_VágadalJoensen
With query.text the results are case sensitive; is this the same case with query.where?
The syntax for query.text seems simpler, but I want to query the server with case insensitive so the server would return the same results for "california" as well as "California", this isn't the case with query.text
KellyHutchins
Esri Notable Contributor
Here's some information from an earlier discussion on the forum that should help:
http://forums.arcgis.com/threads/35878-QUERYTASK-and-case-sensitivity
KellyHutchins
Thank you.
