Web application - multi user editing!
1556
01-19-2012 12:19 PM
FarhadKazemi
I have created a web service (ArcGIS Server) containing a feature class and a table. I am planning to develop a web application which allows users to edit the feature layer and the table. I need help on how to manage a multi user editing (i.e. when 2 or more users attempt to edit the same feature layer in the same time). In desktop applications each user edits his/her own version, but here the service resource points to a one version.
Also:
This would be my first web application with editing functionality.
Replacing the feature class with a file GDB layer makes the work simpler, more difficult, or the same?
Where can I find a sample application or more resources?
Thank you,
Farhad
JianHuang
Farhad,
ArcGIS Server 10.1 will support editing against different GDB versions. Accordingly, JavaScript API will implement it.
Hope this helps.
derekswingley1
Pre-10.1, the last edit that is made is what you'll see.
File GDBs do not support multi-user editing (even when exposed via ArcGIS Server) so fGDB isn't an option if you want to do multi-user editing.
JeffPace
Farhad,
Hope this helps.
This is awesome!!!!!!
FarhadKazemi
Thank you very much guys,
I got the concept!
Farhad
