Hiding multiple feature layers
1988
12-21-2011 03:07 PM
EdSaunders
Hi all,
I've add some feature layers and pushed them into an array like below:
var dwf = "http://<server>/ArcGIS/rest/services/SLR/Water/MapServer/1";
dwfLayer = new esri.layers.FeatureLayer(dwf, {
title : "Drinking water facilities",
infoTemplate : infoTemplate
legendLayers.push({
layer : dwfLayer,
title : 'Drinking water facilities'
Then, in another function, I'd like to switch off all the feature layers so I've tried using:
var len = legendLayers.length;
for (var i = 0; i < len; i++) {
legendLayers.hide();
I've also tried:
dojo.forEach(legendLayers.layer, function(layer) {
layer.hide();
But neither of the above functions work to hide all the layers in the legendLayers array.  I'm obviously missing something. Can anyone help?
Thanks heaps,
Ed
StephenLead
Honored Contributor
but I get the error message "activeLayers.hide is not a function" using:
activeLayers.push([saLayer, wpLayer, dwpLayer, roadsLayer, wfLayer, dwfLayer]);
activeLayers.push({layer:saLayer},{layer:wpLayer},{layer:dwpLayer},{layer:roadsLayer},{layer:wfLayer},{layer:dwfLayer});
Try using push within a for loop, in the same way as you're using hide?
StephenLead
Honored Contributor
Hi Ed,
It looks like you may need another array to hold the feature layers, rather than trying to re-use the one holding the legend layers. You could try something like this:
var fLayers = []; //define a new array for the feature layers
legendLayers.push({
  layer : dwfLayer,
fLayers.push(dwfLayer); //push this layer to the new array (as well as the Legend array)
//Iterate through the feature layers and switch them off
for (var i = 0; i < fLayers.length; i++) {
  var layer = fLayers;
  layer.hide();
Cheers,
Steve
EdSaunders
Steve, thanks for the input mate.  I didn't think it mattered when and how you add layers into an array but it seems it's quite important!  For example, this works:
activeLayers.push(saLayer);
activeLayers.push(wpLayer);
activeLayers.push(dwpLayer);
activeLayers.push(roadsLayer);
activeLayers.push(wfLayer);
activeLayers.push(dwfLayer);
using the loop:
var len = activeLayers.length;
  activeLayers.hide();
Can I not put layers into an array using the two types of syntax above?
Cheers,
Ed
StephenLead
Honored Contributor
EdSaunders
Yeah I was thinking the same thing. I was trying it the same way as map.addLayers. I'll use a loop there as well because I've got a few more layers to add. Thanks mate, have a good Xmas break!
