can you read SOAP services with the JS API?
1109
12-14-2011 09:52 AM
GabrielaLaird
Does anybody know if I can read a SOAP end point of a feature service using the ArcGIS Server JavaScript API? Or does it only works with the service's REST end point?
derekswingley1
The ArcGIS API for JavaScript is built to talk to REST endpoints from ArcGIS Server.
What do you want to do with SOAP?
NianweiLiu
You can try:
https://cwiki.apache.org/CXF20DOC/javascript-clients.html
However, a more realistic approach is probably write a server piece that talks to SOAP end and then output result as JSON with callback.
