Adding Legend, need help to add to my script..
745
12-01-2011 05:16 PM
MatthewLopez
I am having difficulties adding a legend script to my original basemap script. Need guidance or any recommendations, so that I may be able to add (where can I add within the original script) the legend script to my original basemap script? Hope I am saying this correct...
I need to the script within this URL, which is my legend (please see below):
https://gis.sanantonio.gov/ArcGIS/rest/services/BikeFacilities/MapServer/legend
into my original basemap script (please see below):
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
  <html>
  <head>
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>
    </title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/dojo/dijit/themes/claro/claro.css">
    <style type="text/css">
      html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
      #map{
        padding:0;
    </style>
    <script type="text/javascript">
      var djConfig = {
        parseOnLoad: true
    </script>
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.5"></script>
      dojo.require("dijit.dijit"); // optimize: load dijit layer
      dojo.require("dijit.layout.BorderContainer");
      dojo.require("dijit.layout.ContentPane");
      dojo.require("esri.map");
      dojo.require("esri.virtualearth.VETiledLayer");
      dojo.require("dijit.TitlePane");
      dojo.require("esri.dijit.BasemapGallery");
      dojo.require("esri.arcgis.utils");
      dojo.require("esri.dijit.Legend");
      var map = null;
      function init() {
        var initExtent = new esri.geometry.Extent({"xmin":-11209999,"ymin":3481772,"xmax":-10668897,"ymax":3369459,"spatialReference":{"wkid":102100}});
        map = new esri.Map("map",{extent:initExtent});
        var initBasemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer");
        map.addLayer(initBasemap);
var initbikefacilities = new esri.layers.ArcGISTiledMapServiceLayer("https://gis.sanantonio.gov/ArcGIS/rest/services/BikeFacilities/MapServer");
     map.addLayer(initbikefacilities);
var operationalLayer = new esri.layers.ArcGISDynamicMapServiceLayer
map.addLayer(operationalLayer);
//add the legend
        dojo.connect(map,'onLayersAddResult',function(results){
          var layerInfo = dojo.map(results, function(layer,index){
            return {layer:layer.layer,title:layer.layer.name};
          if(layerInfo.length > 0){
            var legendDijit = new esri.dijit.Legend({
              map:map,
              layerInfos:layerInfo
            },"legendDiv");
            legendDijit.startup();
        map.addLayers([operationalLayer]);
        createBasemapGallery();
        //resize the map when the browser resizes
        dojo.connect(dijit.byId('map'), 'resize', map,map.resize);
      function createBasemapGallery() {
        //add the basemap gallery, in this case we'll display maps from ArcGIS.com including bing maps
        var basemapGallery = new esri.dijit.BasemapGallery({
          showArcGISBasemaps: true,
          bingMapsKey: 'A1GXEbIE8xrnP3IbNrLVIqRfH1FLjVX53xuqCMqM2Y1Cvp_ugYoFdPn-Sn2XyX9Q',
          map: map
        }, "basemapGallery");
        basemapGallery.startup();
        dojo.connect(basemapGallery, "onError", function(msg) {console.log(msg)});
      //show map on load
      dojo.addOnLoad(init);
    </script>
  </head>
  <body class="claro">
    <div dojotype="dijit.layout.BorderContainer" design="headline" gutters="false" style="width:100%;height:100%;margin:0;">
<div id="leftPane" class="roundedCorners" dojotype="dijit.layout.ContentPane" region="left"
style="width:275px;">
Legend
</div>
    <div id="map" dojotype="dijit.layout.ContentPane" region="center" style="border:1px solid #000;padding:0;">
      <div style="position:absolute; right:20px; top:10px; z-Index:999;">
        <div dojoType="dijit.TitlePane" title="Switch Basemap" closable="false"  open="false">
          <div dojoType="dijit.layout.ContentPane" style="width:380px; height:280px; overflow:auto;">
          <div id="basemapGallery" ></div></div>
        </div>
      </div>
      </div>
    </div>
  </body>
  </html>
derekswingley1
Hi Matt,
There are a couple of issues with your code:
-only add your bike facilities layer once
-add an HTML element, e.g. a <div>, with an id that matches what you specify in the legend constructor
-modify your layer to have a name or specify one manually
Here's a modified version of the code you posted:
<html>
  <head>
    of the samples on iOS devices-->
    <title>
    </title>
      html, body { height: 100%; width: 100%; margin: 0; padding: 0; } #map{
      padding:0; }
    </style>
    var djConfig = {
  parseOnLoad: true
    </script>
    </script>
    var map = null;
    function init() {
        "xmin": -11209999,
        "ymin": 3481772,
        "xmax": -10668897,
        "ymax": 3369459,
        "spatialReference": {
          "wkid": 102100
      map = new esri.Map("map", {
        extent: initExtent
      var operationalLayer = new esri.layers.ArcGISDynamicMapServiceLayer("https://gis.sanantonio.gov/ArcGIS/rest/services/BikeFacilities/MapServer");
      //add the legend
      dojo.connect(map, 'onLayersAddResult', function(results) {
        console.log("on layers add result: ", results);
        var layerInfo = dojo.map(results, function(layer, index) {
          return {
            layer: layer.layer,
            // title: layer.layer.name // name property is undefined...
            title: "Bike Facilities"
        if (layerInfo.length > 0) {
            map: map,
            layerInfos: layerInfo
          }, "legendDiv");
      dojo.connect(dijit.byId('map'), 'resize', map, map.resize);
        map: map
        console.log(msg)
    //show map on load
    </script>
  </head>
      region="left" style="width:275px;">
        Legend
        <div id="legendDiv"></div>
      </div>
          open="false">
              <div id="basemapGallery">
              </div>
            </div>
          </div>
        </div>
      </div>
    </div>
  </body>
</html>
