How can I open a cacheDataset into a new layer in arcEngine
673
12-01-2011 07:59 AM
TimB
I am trying to load a cacheDataset (name?) that was created using the MapCookerClass as shown in the Multithreaded MapCruncher example at the URL below.  In arcMap it is possible to connect/add this cache using the Add Data dialog.  The ArcEngine dialog does not seem to support this structure so I am trying to do it programmatically.
Do I use a rasterWorkspace to open and connect to this data?  Or, do I need to use something like the DynamicCacheLayerManager?  The latter appeared more likely, but it looks like it is assuming you already have that layer in the map.
I am wanting to add a new layer to the map from the previously created cache for an offline scenario.
Any help/examples would be greatly appreciated.
http://help.arcgis.com/en/sdk/10.0/arcobjects_net/conceptualhelp/index.html#/Sample_Multithreaded_Ma...
TimB
ESRI: The quote below is from your help file that discusses the MapCruncher sample.
So my question is: How do I 'Add the cache as a raster' in ArcEngine?
From the 'How to use' section:
4. Once the cache is finished processing, open Engine or Desktop, navigate to the cache folder, and add the cache as a raster.
