Domain values export
895
11-28-2011 10:12 AM
SubramanianRamakrishnan
I am working with ArcGIS 9.3. When I export any feture class (with coded domain) to dbf, domain description is not getting exported. I need the domain descriptions(instead of domain codes) need to be exported in the dbf file. How to do?
JamalNUMAN
Legendary Contributor
Hi Subramanian,
To avoid this issue in the ArcGIS, I make the code values the same as the description.
As workaround, you need to use “domain to table” and then join this table s with the exported dbf file
Hope this helps
Jamal Numan
