Add map service to ArcMap
3396
11-25-2011 01:44 PM
JerryGarcia
Can someone provide a code snippet to add a map service to ArcMap?
In addition, the map service contains many layers.  I just want to add a few of the many layers.
How can I do this?
Thanks!
seria
by Esri Contributor
The code sample below shows how one can add a map service to ArcMap using the GxCatalog dialog.
 using System;
 using System.Collections.Generic;
 using System.Text;
 using System.IO;
 using ESRI.ArcGIS.ArcMapUI;
 using ESRI.ArcGIS.CatalogUI;
 using ESRI.ArcGIS.Catalog;
 using ESRI.ArcGIS.Carto;
 using ESRI.ArcGIS.Geodatabase;
 using System.Windows.Forms;
 using ESRI.ArcGIS.GISClient;
 using ESRI.ArcGIS.esriSystem;
namespace GxDialog_Select_MapService_Layer
      public class GxDialog_Select_MapService_Layer : ESRI.ArcGIS.Desktop.AddIns.Button
          public GxDialog_Select_MapService_Layer()
          protected override void OnClick()
              IMxDocument pmxdoc = (IMxDocument)ArcMap.Application.Document;
              IMap pmap = pmxdoc.FocusMap;
              IGxDialog pGxDialog = new GxDialog();
               pGxDialog.Title  =  "Browse Data";
              //pGxDialog.set_StartingLocation("C:\\Temp");
               pGxDialog.set_StartingLocation("GIS Servers");
              IEnumGxObject pEnumGx;
              if (!pGxDialog.DoModalOpen(0, out pEnumGx))
                   return; // Exit if user presses Cancel
              IGxObject pgxobject = pEnumGx.Next();
              IGxAGSObject gxAGSObject = pgxobject as IGxAGSObject;
              IAGSServerObjectName agsServerObjectName = gxAGSObject.AGSServerObjectName;
              IAGSServerConnectionName agsServerConnectionName =
                            agsServerObjectName.AGSServerConnectionName;
              IPropertySet propertySet = agsServerConnectionName.ConnectionProperties;
              //create a new ArcGIS Server connection factory
              IAGSServerConnectionFactory2 agsServerConnectionFactory2 =
                             (IAGSServerConnectionFactory2)new AGSServerConnectionFactory();
              IAGSServerConnection agsServerConnection =
                              agsServerConnectionFactory2.Open(propertySet, 0);
               //get an enum of all server object names (services) from the server
              IAGSEnumServerObjectName soNames = agsServerConnection.ServerObjectNames;
              IAGSServerObjectName3 soName = (IAGSServerObjectName3)soNames.Next();
              ILayerFactory msLayerFactory = new MapServerLayerFactory();
              IEnumLayer enumLyrs = msLayerFactory.Create(soName);
              IMapServerLayer mapServerLayer = (IMapServerLayer)enumLyrs.Next();
              pmap.AddLayer(( ILayer)mapServerLayer);
              ArcMap.Application.CurrentTool = null;
