Can a halo be added to a text element which is added to a graphic container?
3618
04-30-2013 12:50 PM
GenaroGarcia
Is there a way to programmatically add a halo to text elements that are being added to a graphic container?
Here's a sample of my code:
    // --- Obtani the area of the polygon to get the centroid of it
    IArea areaOfPolygon = (IArea)polygonEnvelope;
    IPoint TextPoint = new PointClass();
    TextPoint = areaOfPolygon.Centroid;
    // --- Create text symbol
    System.Drawing.Font textDrawFont = new System.Drawing.Font("Arial", 8F, FontStyle.Bold);
    ESRI.ArcGIS.Display.ITextSymbol textFontSymbol = new ESRI.ArcGIS.Display.TextSymbolClass() as ESRI.ArcGIS.Display.ITextSymbol;
    // --- Supply font property values
    textFontSymbol.Font = ESRI.ArcGIS.ADF.COMSupport.OLE.GetIFontDispFromFont(textDrawFont) as stdole.IFontDisp;
    textFontSymbol.Font.Size = 24;
    textFontSymbol.Font.Bold = true;
    textFontSymbol.Angle = 0.0;
    textFontSymbol.Color = rgbTextColor;
    // --- Text to be added to the graphic container
    String sPolygonText = "Need Halo around text";
    // --- Add text element and set properties
    ITextElement textElement = new TextElementClass();
    textElement.Text = sPolygonText;
    textElement.Symbol = textFontSymbol;
    // --- Create element, set property & add to graphic container
    element = textElement as IElement;
    element.Geometry = TextPoint;
    // --- Cast Element to Element Property in order to give it a name
    ESRI.ArcGIS.Carto.IElementProperties3 pTextElementProps = element as ESRI.ArcGIS.Carto.IElementProperties3;
    pTextElementProps.Name = "OKC_Search";
    // --- Add graphic text element to graphic container
    currentGraphicsContainer.AddElement(element, 0);
GenaroGarcia
Yes you can add halo around the text.
// ---    Create halo symbology mask for text   ---
// --- Set the Halo color - White
HaloColor.Red = 255;
HaloColor.Green = 255;
HaloColor.Blue = 255;
// --- Create Halo Font Symbol
HaloFontSymbol.Font =
ESRI.ArcGIS.ADF.COMSupport.OLE.GetIFontDispFromFont(HaloDrawFont) as stdole.IFontDisp;
HaloFontSymbol.Font.Size = 24;
HaloFontSymbol.Font.Bold = true;
HaloFontSymbol.Angle = 0.0;
HaloFontSymbol.Color = HaloColor;
// --- Set the Simple Fill color
SimpleFill.Color = HaloColor;
SimpleFill.Style =
ESRI.ArcGIS.Display.esriSimpleFillStyle.esriSFSSolid;
SimpleFill.Outline = null;
// --- Setup a mask
pMask = (IMask)HaloFontSymbol;
pMask.MaskSymbol = SimpleFill;
pMask.MaskSize = 2;
pMask.MaskStyle = esriMaskStyle.esriMSHalo;
// --- Create and add halo text to graphic container
HaloTextElement.Text = gPolygonText;
HaloTextElement.Symbol = HaloFontSymbol;
HaloElement = HaloTextElement as IElement;
TextPoint.Y -= .5;
HaloElement.Geometry = TextPoint;
container
if (cbDrawResults.Checked)
      SearchGraphicsContainer.AddElement(HaloElement, 0);
GenaroGarcia
SimpleFill.Style =
// --- Setup a mask
pMask.MaskSize = 2;
TextPoint.Y -= .5;
container
