refresh the map when adding new layer
4231
11-20-2011 08:17 PM
salimalzahrani
hi everyone,
i am quite newbie on Javascript API, what i am trying to do is:
i added new layers to the map and need to refresh or reload the map so i can see the new layer
i tried many way mentioned here but nothing works
http://forums.esri.com/Thread.asp?c=158&f=2396&t=259812
this is the error i get always.
[08:59:28.833] _547 is undefined @ http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.5compact:48
here is my code for this idea
    map.removeLayer(tiledMapServiceLayer);
    map.removeLayer(dynamicMapServiceLayer);
    var tiledMapServiceLayer = new esri.layers.ArcGISTiledMapServiceLayer("url");
    map.addLayer(tiledMapServiceLayer);
    var dynamicMapServiceLayer = new esri.layers.ArcGISDynamicMapServiceLayer("url");
    map.addLayer(dynamicMapServiceLayer);
    map.setExtent(map.extent);
JeffPace
hi everyone,
both addLayer and setExtent should refresh your map, but you are not creating valid layers.
you are passing in the String "url", you need to send the actual url.
salimalzahrani
this is only to shorten the line
salimalzahrani
i wrote "url" just to shorten the line 🙂
my map is working but i need to be able to change the service layer from one service to another
JasonSandall
Use the destroy method.
destroy()
Destroys the map instance. After the map is destroyed it is no longer valid however you can re-use the div element of the map to create a new map instance. (As of v2.0)
Return value: none
Code snippets:
map.destroy();
