Query Object Attributes from CGA
3942
11-14-2011 07:23 AM
Jackde_Valpine
I am subdividing imported blocks using a python script. I note that the subdivision is automatically generating a potentially handy boolean "Object Attribute" for each resulting lot called "enclosed." However, I do not get how I can access this attribute from a CGA applied to the blocks? I see in the documentation a function called "getObjectAttr," however this function does not seem defined in CGA?
Any direction would be welcome.
-Jack
MatthiasBuehler1
hi Jack.
first, you need to initialize the attr in the CGA rule file.
see this code :
attr enclosed = false
Lot -->
 case enclosed == true :
  color("#ff0000")
 else:
  color("#00ff00")
once you have assigned the rule, change the Attribute Source to 'Object attribute'.
In the 2011 version, this is done with the little black triangle on white rectangle next to the attr entry in the Inspector.
Ok ?
Jackde_Valpine
Hi Matthias,
Thanks for the follow-up, I had just managed to finally get this figured out with some more exploration!
-Jack
hi Jack.
see this code :
Lot -->
  color("#ff0000")
 else:
  color("#00ff00")
Ok ?
