suite de topique.  problem.
1839
11-15-2011 08:00 AM
BENOITBastien
http://forums.esri.com/cityengine/forum-37487.html
Bonjour, j'ai toujours un problème, cette fois-ci, c'est ça :
Hello, I still have a problem, this time, right :
MatthiasBuehler1
hi !
maybe it's best that each topic has a well-descriptive title, .. better than 'help me' or 'problem'. 🙂
color("#ff0000") is the old hexadecimal color code for red.
color(1,0,0) is rgb (0-1, not 0 - 255 !) color code for red. this can be used only in 2011 and after.
so you need to write the hex version in 2010.3, ok ?
BENOITBastien
Oui, je vois le rouge sur la route. ^^
Il y a t'il une suite de code cga pour voir les grillages et les barrière de sécurités ?
I see the red on the road.
Is there a continuation of cga code to see wire nettings and guardrails ?
Is this a good sign ?
Sorry for the title.
MatthiasBuehler1
the current examples are not that detailed, but you could also create details as guard rails and such in cga.
it's just a question of how much detail you want / need.
as the name says the examples are examples, but do not represent the quality of what details can be ultimately be produced. The more time you invest in details and in CGA code, the more details you can produce. 🙂
