query is undefined
2842
11-08-2011 06:31 AM
MikeOnzay
I built this code from this example page here on how to use a querytask. I changed the fieldname being used in the where clause because the field in the example doesn't exist. I tested my query out using the query window in the services directory and it worked fine.
When I run this code I get "query is undefined". I don't know why.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <title>State Info</title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/dojo/dijit/themes/tundra/tundra.css">
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.5"></script>
    <script type="text/javascript">
      dojo.require("esri.tasks.query");
 var query, queryTask;
function init() {
    //create map and add layer
    map = new esri.Map("mapDiv");
    var layer = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer");
    map.addLayer(layer);
    //initialize query task
    queryTask = new esri.tasks.QueryTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/0");
    //initialize query
    query = new esri.tasks.Query();
    query.returnGeometry = true;
    query.outFields = ["CITY_NAME", "STATE_NAME", "POP1990"];
    //initialize InfoTemplate
    infoTemplate = new esri.InfoTemplate("${CITY_NAME}", "Name : ${CITY_NAME}<br/> State : ${STATE_NAME}<br />Population : ${POP1990}");
    //create symbol for selected features
    symbol = new esri.symbol.SimpleMarkerSymbol();
    symbol.setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE);
    symbol.setSize(10);
    symbol.setColor(new dojo.Color([255,255,0,0.5]));
  function executeQueryTask(population) {
   //set query based on what user typed in for population;
    query.where = "POP1990 > " + population;
    //execute query
    queryTask.execute(query,showResults);
  function showResults(featureSet) {
    //remove all graphics on the maps graphics layer
    map.graphics.clear();
    //Performance enhancer - assign featureSet array to a single variable.
    var resultFeatures = featureSet.features;
    //Loop through each feature returned
    for (var i=0, il=resultFeatures.length; i<il; i++) {
      //Get the current feature from the featureSet.
      //Feature is a graphic
      var graphic = resultFeatures;
      graphic.setSymbol(symbol);
      //Set the infoTemplate.
      graphic.setInfoTemplate(infoTemplate);
      //Add graphic to the map graphics layer.
      map.graphics.add(graphic);
</script>
  <body>
    <br/>
    US city population greater than : <input type="text" id="population" value="500000" />
    <input type="button" value="Get Details" onclick="executeQueryTask(dojo.byId('population').value);" />
    <div id="mapDiv" style="width:600px; height:600px; border:1px solid #000;"></div>
    Click on a city once it's highlighted to get an InfoWindow.
  </body>
</html>
KellyHutchins
Esri Notable Contributor
Mike,
The init function wasn't getting executed because the code is missing the following:
dojo.addOnLoad(init);
Here's a modified version that should work:
<html>
  <head>
function init() {
    //initialize query
    symbol.setSize(10);
    //execute query
</script>
  <body>
    <br/>
  </body>
</html>
MikeOnzay
Thanks. I knew it had to be something simple. The fact that no map appeared at first should have been my first clue.
