Field calc failure, division?
5531
11-04-2011 01:21 PM
ForrestEnglish
I'm trying to a percent change for some fields.  I have the amount increased by, and I have the previous value.  So I made a new field, and asked the field calc to [Increase] / [Previous].  It fails, and gives me the following.
General error executing calculator.
ERROR 999999: Error executing function.
Overflow
Failed to execute (CalculateField).
It's a fairly basic operation, and works even on a cheap calculator.  Anyone know what I'm doing wrong?
DarrenWiens2
MVP Honored Contributor
Is there any case where [Previous] = 0? If so, ArcMap gets confused when dividing by 0 (I bet your cheap calculator does, too). Skip over 0s with the code block.
NobbirAhmed
Also, make sure the target field type is Double with sufficient storage to hold the resulting value.
