TimeExtent and Query issue
2798
8
10-24-2011 08:46 AM
deleted-user-VeZur_n9o0OZ
Hello experts,
I'm using firebug to step through my app. I am using a single time slider (with only one thumb) to query two feature layers loaded into seperate maps. I've followed the samples but my code seems to die on the first line in my connector method; query = new esri.tasks.Query();
query is a public variable and I have included the necessary dojo.require for the query task. I can't catch the error with a try catch either. Anyone know what's going on?
Code below.
James
try {
      //Connect time slider events
      dojo.connect(timeSlider, "onTimeExtentChange", function(timeExtent) {
       query.timeExtent = timeExtent;
       flITIS.queryFeatures(query, function(featureSet) {
        //empty function for now
       flLCAP.queryFeatures(query, function(featureSet) {
     } catch(err) {
      alert("Error: " + err.message + ", Line #" + err.lineNumber);
KellyHutchins
Esri Notable Contributor
Is query in lower case in your dojo.require statement, for example:
   dojo.require("esri.tasks.query");
Also have you checked either Firebug or Chrome Developer Tools to see if there are any error messages?
Hi Kelly,
thanks for your comments. My requires statement is correct. I don't think it's an issue with the Query. I have now declared a seperate function to listen to my onTimeExtentChange. It seems that the debugger in firebug will stop at my breakpoint on the first executable line of code. After that, it will not stop at any other breakpoints, but WILL execute the code. In the snippet below I will always see the alert about my start and end times of my query. Ever seen that before? I haven't used Chrome but will do so this afternoon.
     dojo.connect(timeSlider, "onTimeExtentChange", extentChanged(timeExtent));
    } catch(err) {
   function extentChanged(timeExtent) {
    try {
     var queryITIS = new esri.tasks.Query();
     var queryLCAP = new esri.tasks.Query();
     queryITIS.timeExtent = timeExtent;
     queryLCAP.timeExtent = timeExtent;
     flITIS.queryFeatures(queryITIS, function(featureSet) {
     flLCAP.queryFeatures(queryLCAP, function(featureSet) {
     alert("Start time: " + queryITIS.timeExtent.startTime.toLocaleTimeString() + ", End time: " + queryITIS.timeExtent.endTime.toLocaleTimeString());
    } catch(err) {
On a seperate note, I am seeing an error in my console. The error is thrown when I click 'Next' on my time slider. It is as follows:
lls is null.
Does this mean anything to you? I would expect clicking next to trigger my extentChanged function
Update: Chrome error console now tells me:
Uncaught Could not load cross-domain resources: dojox.gfx.svg esri.nls.jsapi_en-gb dijit.layout.BorderContainer dijit.layout.ContentPane dijit.Toolbar esri.layers.FeatureLayer esri.dijit.Legend esri.dijit.Popup esri.dijit.TimeSlider
Ok people - this is really baffling me. My code is now practically identical to the official sample here:
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm
on the line timeSlider.startup() the following error is thrown:
"Cannot call method 'apply' of null"
I've sunk a few hours into this time slider now and really need it working...any input appreciated.
James
     //Timeslider stuff
     var timeExtent = new esri.TimeExtent();
     timeExtent.startTime = new Date("9/1/2011 15:00:00 UTC");
     timeExtent.endTime = new Date("9/1/2011 23:00:00 UTC");
     //create the div
     var tsDiv = dojo.create("div", null, dojo.byId('timeSliderDiv'));
     var timeSlider = new esri.dijit.TimeSlider({
      style : "width: 90%;",
      options : {
       excludeDataAtLeadingThumb : true
     }, tsDiv);
     //dojo.connect(timeSlider, "onTimeExtentChange", function(timeExtent){
     //set map timesliders
     mapITIS.setTimeSlider(timeSlider);
     //mapLCAP.setTimeSlider(timeSlider);
     timeSlider.setThumbCount(2);
     timeSlider.createTimeStopsByTimeInterval(timeExtent, 5, 'esriTimeUnitsMinutes', {
      resetStartTime : true
     //a tick for each 30mins
     //timeSlider.setTickCount(17);
     //timeSlider.singleThumbAsTimeInstant(true);
     timeSlider.setThumbIndexes([0, 1]);
     timeSlider.setThumbMovingRate(500);
     timeSlider.setLoop(true);
     timeSlider.startup();
     var labels = ['16:00', '17:00', '18:00', '19:00', '20:00', '21:00', '22:00', '23:00', '00:00'];
     timeSlider.setLabels(labels);
KellyHutchins
Its hard to know what's happening without seeing more code. Is your service public? If so can you create a test case that shows the problem?
Morning Kelly.
Oddly, I have now worked around the error messages i was seeing with the following code. I went back to using an anonymous function for my timeslider connection. Also, I declared a seperate function for my timeslider initialisation after my feature layers are finished loading. Thanks for the continued support Kelly...
Time extent setup and connector:
//Timeslider stuff
     flITIS.setTimeDefinition(timeExtent);
     flLCAP.setTimeDefinition(timeExtent);
     //create the div
      options : {
       excludeDataAtTrailingThumb : true
     }, tsDiv);
     //dojo.connect(timeSlider, "onTimeExtentChange", extentChanged(timeExtent));
      try {
       //update label for slider
       updateTimeString(timeExtent);
       //alert("Start time: " + queryITIS.timeExtent.startTime.toLocaleTimeString() + ", End time: " + queryITIS.timeExtent.endTime.toLocaleTimeString());
      } catch(err) {
Time slider setup:
//when the LCAP fl is loaded, initiate the slider
dojo.connect(flLCAP, "onUpdateEnd", timeSliderInit(timeExtent));
function timeSliderInit(timeExtent) {
    timeSlider.setThumbMovingRate(1500);
DavidHollema
If you're still having trouble with this and post all your code, I will take a look.  I'm curious why your named function for the timeslider event was problematic.
Salomon_VágadalJoensen
The query task is case sensitive. Thought I would want to throw it out there.
