Replace ESRI logo with custom logo?
22271
34
10-17-2011 10:37 AM
BarryGuidry
I've found how to insert a custom logo into the header of a web application, but how can one replace the "Powered by ESRI" logo?
JoeJeurissen
Set the logo to false in the parameter options of the map constructor.
Example:
var map = new esri.Map("map",{logo:false});
Then position your logo where you want in the map container.
BaileyLipscomb1
If you are trying to replace just the image it can be accomplished by the following code:
<script type="text/javascript">
    //Change the background image
    document.getElementsByClassName('logo-med')[0].style.backgroundImage="url(\"http://www.yoururl.com/to/the/image.gif\")";
    //Keep the image from repeating
    document.getElementsByClassName('logo-med')[0].style.backgroundRepeat="no-repeat";
</script>
martinschmoll
</script>
When the user clicks the logo it links to esri.com.  How do you disable that, or better yet change the url?
BarryGuidry
</script>
Thanks, Bailey.  I cannot figure out where to insert it in the HTML file, though.
BaileyLipscomb1
Drop it in the header below all of the ArcGIS javascript functions. Let me know if that works.
martinschmoll
I found it in old API documentation...
esri.config.defaults.map.logoLink = "http://yoursite.com"
BarryGuidry
Martin, that is also on Utah's GIS Portal.  That is only a portion of what needs to be completed, though, which only adds a custom hyperlink to the logo. I attempted what Utah's site recommends, but it only deleted ESRIs logo, but did not add mine.
martinschmoll
I've got both the replacement logo and url working.  Make sure you post the (3 lines of) code in your init() function after the map object is created.
BarryGuidry
Three lines of code? Not sure which code you are using (perhaps a combination of what Bailey and yourself posted)?
Is there an additional "dojo.require" statement that may be necessary?
