Python calculation in field calculator
4486
10-17-2011 01:43 AM
KathrinSchulte-Braucks
I'm trying to do some simple calculation within the field calculator using Python instead of VB and keep on getting error messages.
Pre-logic script code:
def rad (value):
  return math.sqrt(value / math.pi( ) )
Expression:
AEQU_RAD= rad (!area!)
I get the error message, that "float object is not callable". Field type is double.
DanPatterson_Retired
pi() is the problem, see below
>>> import math
>>> print math.pi
3.14159265359
>>> print math.pi()
  File "<interactive input>", line 1, in <module>
TypeError: 'float' object is not callable
Thank you so much, now it works. I just clicked on the proposed function in the box on the right. The implemented syntax in the box was math.pi(), so I assumed this is the correct syntax.
ChrisFox3
Hi Kathrin,
Thank you for pointing out this issue. I logged a bug for math.pi and math.e constants being listed as functions in the field calculator, NIM074191.
Thanks for processing this issue!
