two maps in app - not overview
1875
10-14-2011 04:10 AM
deleted-user-VeZur_n9o0OZ
Hi all,
I'm writing an app which requires two seperate maps. They need to display difference featurelayers but be responsive to changes in extent to one another. I've managed to create two basic maps and add a baselayer to both. However, I only have control over the second map i.e if i click and pan the left hand map - the right hand map moves. Can i pass control to a map depending on where I've clicked? In the overview map sample you are not able to do this to the overview map.
James
HemingZhu
Hi all,
James
I think a feasible way to achieve your goal is to activate and synchronize both  map's OnExtentChange event and make sure the two map have the same extent all the time.
derekswingley1
The "Compare Web Maps" template on arcgis.com does this, here's an example:  http://apps.arcgis.com/hosted/Compare/Configure/index.html?webmap=ce4cbe1d06e2484284ffd692dfa62545
Make sure you check on "scale" and "location" under synchronize maps near the bottom of the page.
Derek thanks for pointing me towards that template. It has all the functionality and more that I need in my app. I have dowloaded the source and tried to take the pieces of code i need. I've noticed in my left hand map my basemap does not refresh when I navigate but my operational layer does. Has anyone observed that behavoir?
James
Derek,
As per my post here:http://forums.arcgis.com/threads/33051-How-to-refresh-map
I was able to resolve the issue by creating two seperate basemap objects rather than adding the same one to both maps.
James
