KML linkInfo ex. name snippet
2075
9
10-06-2011 03:00 PM
NahmLee
Q. How to get "name" or "snippet" from KML file?
ex. ESRI ex. name should be WY.kml.
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/kmllayer.htm#featureInfos
<Object> linkInfo
A link info object with properties that describe the network link. The object has the following properties:
  "id": <Number>,
  "name": <String>,
  "description": <String>,
  "snippet": <String>,
  "visibility": <Number>
  "refreshMode": <String>,
  "refreshInterval": <Number>,
  "viewRefreshMode": <String>,
  "viewRefreshTime": <Number>,
  "viewBoundScale": <Number>,
  "viewFormat": <String>,
  "httpQuery": <String>
ESRI ex. http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm?KMLLayer
derekswingley1
Once your KMLLayer loads, call getLayers() on it. This will return the feature layers that make up the KMLLayer (one for each type of geometry present for a possible total of three- points, lines, polygons). Once you have you feature layer, loop through the graphics and look at the attributes.name property for each graphic.
If you run this JS on the simple KMLLayer sample:
map.getLayer(map.graphicsLayerIds[0]).graphics[0].attributes.name
It will print "Wyoming(WY)"
NahmLee
derekswingley1
My previous comment still applies...give it a try and let us know if you have any issues.
NahmLee
I need to study more because didn't get it yet.
NahmLee
It works in a strange way but I think it was an accident...
https://s3.amazonaws.com/Nahm/KML/KML4.html
function NameKML(){
var folders = kml.folders;
dojo.forEach(folders,function(folder){
  alert(kml.folders[0].name);
  alert(kml.folders[1].name);
NahmLee
KML file tags display if button is clicked but I can't write them in a innerHTML when KML is loaded in init() function. Why???
<!doctype html>
<html lang="en">
<head>
<title>KML name</title>
<meta charset="utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
<title></title>
<link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/dojo/dijit/themes/tundra/tundra.css">
<link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/esri/dijit/css/Popup.css"/>
<style>
html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
#map { margin: 0; padding: 0; }
#meta {
  position: absolute;
  left: 60px;
  Top: 20px;
  width: 300px;
  height: 300px;
  z-index: 40;
  background: #fff;
  color: #777;
  padding: 5px;
  border: 5px solid #777;
  -webkit-border-radius: 5px;
  -moz-border-radius: 5px;
  border-radius: 5px;
  font-family: arial;
  font-size: 0.9em;
#meta h3 {
  color: #000;
  font-size: 1.1em;
  padding: 0px;
  margin: 0px;
  display: inline-block;
#loading {
  float: right;
</style>
<script>var dojoConfig = { parseOnLoad: true };</script>
<script src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.5"></script>
<script>
dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.ContentPane");
dojo.require("esri.map");
dojo.require("esri.layers.KMLLayer");
var map, resizeTimer;
var kmlUrl, kml;
function init() {
var initExtent = new esri.geometry.Extent({"xmin":-15042310.65,"ymin":1599979.71,"xmax":-6236764.99,"ymax":7470343.49,"spatialReference":{"wkid":102100}});
map = new esri.Map("map",{ extent: initExtent });
var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer");
map.addLayer(basemap);
kmlUrl = 'http://www.hpc.ncep.noaa.gov/kml/qpf/QPF6hr_f00-f06_latest.kml';
kml = new esri.layers.KMLLayer(kmlUrl);
map.addLayer(kml);
//it doen't work????
document.all.here.innerHTML=kml.folders[1].name+" : <br />"+kml.folders[1].snippet;
function NameKML(){
alert("kml name : " +kml.folders[1].name);
alert("kml snippet : "+kml.folders[1].snippet);
alert("kml description : "+kml.folders[1].description);
document.all.meta.innerHTML=kml.folders[1].description;
dojo.ready(init);
</script>
</head>
<body class="tundra">
<div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width: 100%; height: 100%; margin: 0;">
  <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'">
   <div id="meta">
    <h3>Display KML Using a <a href="http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/kmllayer.htm">KMLLayer</a></h3>
    <br />
    <input type="button" value="Name KML" onclick="NameKML();" /><br />
    <div id="here">
    </div>
   </div>
  </div>
</div>
</body>
</html>
derekswingley1
JavaScript executes asynchronously so the code to create your KMLLayer starts but isn't finished when you're trying to access the folders property. To get your folder info, connect to the KMLLayer's onLoad event:
map.addLayer(kml);
dojo.connect(kml, 'onLoad', function(kl) {
  alert('kml loaded. folder[1].name is: ' + kl.folders[1].name);
This pattern applies to all layer types in the JS API.
NahmLee
Thank you very much!!!
It works fine now.
https://s3.amazonaws.com/Nahm/KML/KML_Name_Final.html
Nahm
derekswingley1
Glad you got it working!
