Editing map using Proxy
12172
20
09-27-2011 08:10 PM
shwetakunjadia
Hi All,
I am using arcgis server 10..
Javascript api 2.5
Editing map sample
I followed all steps to create Proxy on arcgis server..
I am not able to add any feature on map 😞
Error on fire  bug:
Error: Unable to load http://arcgis:8399/proxy/proxy.jsp?http://arcgis:8399/arcgis/rest/services/app1/FeatureServer/18/app... status:0
()?v=2.5 (line 14)
undefined = "[object Object]"
()?v=2.5 (line 14)
()?v=2.5 (line 14)
undefined = "-2"
(function(){var _1=null;if((_1||(typeo...etTimeout(dojo._loadInit,100);}})();
Please help me where i am going wrong ???
shwetakunjadia
Can anyone tell me where to set proxy.jsp ??
on server or on local machine??
Please someone help me.....
Shweta
derekswingley1
Your proxy has to live on the same server as your JS API app.
Are you able to contact support for help? This is something that they should be able to walk you through.
shwetakunjadia
yes both are on the same server still not getting 😞
Shweta
derekswingley1
Please contact support if you're unable to get it working by following the steps outlined here:  http://help.arcgis.com/en/webapi/javascript/arcgis/help/jshelp/ags_proxy.htm
shwetakunjadia
Is it Free to contact support team ???
derekswingley1
Unfortunately, no.
shwetakunjadia
Is it necessary to set proxy page while i m edit/add feature on layer ??
Is there any other way in java script api ???
Shweta
nicogis
- have you tried insert feature from rest page?
- have you configurated serverUrls in page proxy?
- can you do debug on page.jsp calling page  http://arcgis:8399/proxy/proxy.jsp?h.../18/applyEdits ?
shwetakunjadia
Hello Alll,
Can anyone tell me is therr anything wrong in proxy.jsp file??
Code:
<%@page session="false"%>
<%@page import="java.net.*,java.io.*" %>
String[] serverUrls = {
"http://server:8399/arcgis/rest/services/"
try {
String reqUrl = request.getQueryString();
boolean allowed = false;
String token = null;
for(String surl : serverUrls)
String[] stokens = surl.split("\\s*,\\s*");
if(reqUrl.toLowerCase().contains(stokens[0].toLowerCase())) {
allowed = true;
if(stokens.length >= 2 && stokens[1].length() > 0)
token = stokens[1];
break;
if(!allowed) {
response.setStatus(403);
return;
if(token != null) {
reqUrl = reqUrl + (reqUrl.indexOf("?") > -1 ? "&" : "?") + "token=" + token;
URL url = new URL(request.getQueryString());
HttpURLConnection con = (HttpURLConnection)url.openConnection();
con.setDoOutput(true);
con.setRequestMethod(request.getMethod());
int clength = request.getContentLength();
if(clength > 0) {
con.setDoInput(true);
InputStream istream = request.getInputStream();
OutputStream os = con.getOutputStream();
final int length = 5000;
byte[] bytes = new byte[length];
int bytesRead = 0;
while ((bytesRead = istream.read(bytes, 0, length)) > 0) {
os.write(bytes, 0, bytesRead);
out.clear();
out = pageContext.pushBody();
OutputStream ostream = response.getOutputStream();
response.setContentType(con.getContentType());
InputStream in = con.getInputStream();
int bytesRead = 0;
while ((bytesRead = in.read(bytes, 0, length)) > 0) {
ostream.write(bytes, 0, bytesRead);
} catch(Exception e) {
response.setStatus(500);
Please help me i want it to be working as soon as possible 😞
Shweta
