Map Loading Progress Bar
4608
6
09-02-2011 05:28 AM
LawrenceDhliwayo
Is there a way to implement a map loading progress bar is in the Silver light API? When a user zooms the map, or loads a new layer, the progress bar shows and makes aware the user that we are waiting on some results from the server.
I would be looking for a way to have this attached to events which depend on server results such as my layer loading events and find tasks as I have lots of data being displayed.
I have tried checking in the forums with no luck. Any leads would be most appreciated.
Lawrence
JeffPace
Since you posted in the javascript forum, here is a js example
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples/map_showloading.html
I imagine Silverlight might have a similar one.
LawrenceDhliwayo
Thanks Jeff,
Thats exactly what I was looking for !
Lawrence
jerrysalinas
I was wondering if there is another example on how to use the progress bar. I clicked the link in the thread but it has been removed. i am trying to add a progress bar when the map loads or when layers are added.
Thanks.
Jerry
LawrenceDhliwayo
Thanks.
Jerry
Hi unfortunately I can't find the link either. But here is what u can do:
Have a some html mark up like so:
                <span id="status" style="position: absolute; z-index: 100; right: 350px; top: 200px;">Loading...
                </span>
And css like so:
#status
    background-color: black;
    color: white;
    padding: 3px;
    border: solid 3px white;
    border-radius: 5px;
And in your script u can call esri.show(dojo.byId("status")) at the start of you long running process and  esri.hide(dojo.byId("status")) after the end of the long running process.
Hope that helps,
Lawrence
jerrysalinas
Thanks Lawrence for info, I was able to use it. I got it to work, just needed to also add this below.
dojo.connect(map, "onUpdateStart", function(){
          esri.show(dojo.byId("status"));
        dojo.connect(map, "onUpdateEnd", function(){
          esri.hide(dojo.byId("status"));
Regards.
KenBuja
MVP Esteemed Contributor
