Json Geometry Object - how to set size of point marker symbol?
511
08-22-2011 06:30 AM
ChrisBuckmaster1
Hi
I am using the Map2PDF REST service provided by Rahul Ravikumar and am trying to set the point symbol's style when graphics are added to the map. When I set this within my API it does not seem to translate over to the js file so I am looking at altering the code within the js file itself...
The following code is what is provided when setting the point symbol:-
else if (geometry instanceof esri.geometry.Point) {
          geometries.push({
            "geometryType" : "esriGeometryPoint",
            "x" : geometry.x,
            "y" : geometry.y,
            "symbol" : graphics.symbol.toJson()
How can this be modified to specifically set the size of the point?
JeffPace
Well right now you are just pushing in the existing symbol.  So before the push, you can override the symbology.
var symbol = graphics.symbol;
symbol.setColor(new dojo.Color([255,255,0,0.5])); //change to what you want here
//then pass the modified symbol instead of the default
          geometries.push({
            "x" : geometry.x,
            "y" : geometry.y,
            "symbol" : symbol.toJson()
Hi
          geometries.push({
            "x" : geometry.x,
            "y" : geometry.y,
