Script Tool Return Value
2664
5
08-11-2011 08:59 AM
JeffWard
Honored Contributor
I am trying to set up a model to do a task that I do every month.  Part of that model is a stand-alone python script that creates a file name with the date tagged on to the end of it.  How do I write my script so that it returns this string and I can use it as input for another geoprocessing tool?  I have searched the forums and help, but can't find any examples of this.
Any help is much appreciated.
Jeff
Jeff Ward
Summit County, Utah
MikeMacRae
Are you trying to use the current date or a date that you want to set?
If so, try importing datetime, create the date and then pass it to a string variable. From there, build your file name and concatenate your string date variable where you want it.
x = str(yourdatevariable)
Here are some good examples on how datetime works.
http://www.saltycrane.com/blog/2008/06/how-to-get-current-date-and-time-in/
JasonScheirer
Esri Alum
You can set up an output parameter of type string and then use SetParameterAsText to populate the value at the end of your script.
JeffWard
Honored Contributor
Thanks for the quick responses.  After looking into the output parameter, I have added my script to the model as a script tool and created an output parameter as a string type.  The file name is hard coded into the script, so I don't have any parameters in the script.  Do I need to create one for the setParameterAsText?  Can you point me to some examples of what the a script with an output parameter looks like and I can figure out how to plug it into the model?
Thanks again for the quick replies.
Jeff Ward
Summit County, Utah
DaleHoneycutt
See Setting script tool parameters.  It appears you want a single derived output parameter, so pay particular attention to the write-ups about derived output parameters.
JeffWard
Honored Contributor
Thanks everyone for your help.  Thanks for that link Dale, that is what I needed to get what I was calling a return value.  I created a derived output string parameter for my script tool and added this line to the end of my script: arcpy.SetParameterAsText(0, fileName).
Thanks again.
Jeff Ward
Summit County, Utah
