Setting zoom level problem
5653
08-09-2011 02:22 AM
yeungyeung
Recently I'm planning to write a web site which containing 2 tab, Menu(tab1) and Map(tab2).
But I face a problem when I try to write it.
When I run the program with VS2010, and then click the map tab(tab2), that the map zoom to maximize level, so that "map data not yet available" message occur. I need to set the zoom level manually...
Following is the code, can anybody suggest a solution, so that it can automatically set to e.g. level 5 when I click the map tab?
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head runat="server">
    <title>Testing</title>
    <script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/dojo/1.6/dojo/dojo.xd.js"  djConfig="parseOnLoad: true"></script>
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.4"></script>
    <script type="text/javascript">
        dojo.require("dijit.layout.TabContainer");
        dojo.require("dijit.layout.BorderContainer");
        dojo.require("dijit.layout.ContentPane");
        // Map
        dojo.require("esri.map");
        dojo.require("esri.dijit.AttributeInspector-all");
     </script>
     <link rel="stylesheet" type="text/css" href="http://ajax.googleapis.com/ajax/libs/dojo/1.6/dijit/themes/claro/claro.css"/>
         var map;
         var Layer;
         function init() {
             //esri.config.defaults.io.proxyUrl = "proxy.ashx";
             var initalExtent = new esri.geometry.Extent({ "xmin": -13188594, "ymin": 4084405, "xmax": -13173402, "ymax": 4095030, "spatialReference": { "wkid": 102100} });
             map = new esri.Map("map", { extent: initalExtent });
             var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer");
             map.addLayer(basemap);
             map.setLevel(5);
             Layer = new esri.layers.FeatureLayer("http://sampleserver5.arcgisonline.com/ArcGIS/rest/services/Energy/Geology/FeatureServer/9", {
                                            mode: esri.layers.FeatureLayer.MODE_ONDEMAND,
                                            outFields: ["station_id","lithology_type","metamorphic_facies","geomodifications"]
             Layer.setSelectionSymbol(new esri.symbol.SimpleFillSymbol());
        map.addLayers([Layer]);
        var resizeTimer;
        dojo.connect(map, 'onLoad', function (theMap) {
            dojo.connect(dijit.byId('map'), 'resize', function () {  //resize the map if the div is resized
                clearTimeout(resizeTimer);
                resizeTimer = setTimeout(function () {
                    map.resize();
                    map.reposition();
                }, 500);
        dojo.addOnLoad(init);
     </script>
</head>
<body class="claro">
    <div id="tabContainer" dojoType="dijit.layout.TabContainer" style="width: 100%; height:600px;" doLayout="false">
        <!--Form-->
         <div dojoType="dijit.layout.ContentPane" title="Menu" style="width: 100%; height:500px;">
          </div>
         <div id="MapTab" dojoType="dijit.layout.ContentPane" title="Map" style="width: 100%; height:500px;" >
             <div dojoType="dijit.layout.BorderContainer" design="sidebar" gutters="true" liveSplitters="true" id="Div1">
                <!--Map Menu-->
                <div id="MapMenu" dojoType="dijit.layout.ContentPane" splitter="true" region="leading" style="width: 100px;">
                </div>
                <!--Map-->
                <div id="map" dojoType="dijit.layout.ContentPane" splitter="true" region="center" style="overflow:hidden;">
                </div>
            </div>
        </div>
</body>
</html>
AxelSchaefer
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi_start.htm
map.setLevel(level) Sets the map to the specified level ID. Zooms to the new level based on the current map center point. Valid only with an ArcGISTiledMapService layer.
Or for example:
map.setExtent(esri.geometry.getExtentForScale(map, scale), fit?)
Second: Don't mess the JS-API with the dojo library. Dojo 1.6.1 is shipped with the JS-API. You refer to:
and
and your CSS is coming from:
You only need:
<link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.4/js/dojo/dijit/themes/claro/claro.css">
and
It's possible to use another DOJO version with the JS-API but I guess you don't need that yet. I advice you to read the Concepts at: http://help.arcgis.com/en/webapi/javascript/arcgis/help/jshelp_start.htm and check the basic examples in the documentation.
Hope that helps
Axel
yeungyeung
Thank you for your replying. I solved the problem of zoom level.
But I still have a question. That is when I don't contain the following code
then dijit.layout.TabContainer and BorderContainer etc will not function normally... Therefore, is my code having some bug?
JeffPace
Since the javascript API includes dojo, you don't need to call the full path to a standalone dojo.
all you need is
dojo.require("dijit.layout.BorderContainer ");
etc..
yeungyeung
Thank you for your reply. All problem solved.
