query operation order by
2484
8
07-28-2011 04:03 PM
LukePhilips
is it possible to query a service and have it return an order set of data? it seems the result set of a query envelope is a random order. essentially the ordered attribute is a market value and I want an those points with the highest market value up until I hit the max returned results parameter. e.g. the 500 highest valued points for any given envelope.
LukePhilips
this is very close to my issue:
http://forums.arcgis.com/threads/2789-order-querytask-results
likewise it seems the 'order by' in the where clause works by accident. It works when only a where statement is populated and nothing else, it does not work when I enter any kind of filter geometry.
SrinivasVinnakota
Query operations at 10.0 and prior releases do not support ORDER BY clause.
LukePhilips
what's the plan going forward?
SrinivasVinnakota
this feature should be available at 10.1
LukePhilips
will I see this feature in the 10.1 beta?
SrinivasVinnakota
Yes, it is available in Beta 1.
OrlandoCarvajal
Will it be possible to use this ORDER BY parameter combined with "returnIdsOnly" so the Ids get returned in a particular order?
SrinivasVinnakota
Neocan,
  "orderByFields" can be used combination with "returnIdsOnly" to return object ids in the desired order.
