JTX 9.3.1 - Cannot Add Data
2895
06-22-2011 05:06 AM
CraigMark
I'm configuring a job template in arcmap via JTX configuration manager.  When I try to add data with the "Job Tracking (Administrator)" toolbar, I get an error:
System.Runtime.InteropServices.COMException (0x80004005): Error HRESULT E_FAIL has been returned from a call to a COM Component. as ESRI.ArcGIS.Catalog.IGxDataset.geet_Dataset() at ESRI.ArcGIS.JTXExt.AddDataConfig.OnClick()
Any help is appreciated!
- Craig
RaghavendraSunku
Hi Craig,
Do you have any 'unusual' datasets in the data workspace you are trying to add from? For example, a feature dataset whose feature classes you do not have permissions to see.
Do you have any datasets that are not feature classes at the top-level in the data workspace?
Raghu
CraigMark
rsunku, thanks for the reply.
There is nothing unusual about the data or schema.
We are using geodatabase user schemas.  I have one WMX connection with all of our user schema workspaces.  When I try to add data via the Workflow Manager Admin toolbar, from one of the other user schemas - A dialog box comes up and shows the data (via the jtx connection), I select the dataset and "Error HRESULT E_FAIL has been returned from a call to a COM component.
I've added other workspaces... Same error.
- Craig
CraigMark
Solution - Privileges...
